Home -> Forums -> Construction -> Safety Tips -> SLAB LOADING
SLAB LOADING
Sat Dec 19, 2015Total posts : 3
ANISH
ANISH
Topic: SLAB LOADING
      In Portico of 6.00 x 3.00 span -12 cm thick slab - double layered reinforcement- for the purpose of providing ornamental elevation rcc pillar of 30 cm dia to a height of 10 m. It is proposed a have a RCC Pedestal of size 0.45x0.45m x6.00 over the slab  which is 0.45 from continous span over which the column is to be place. Is it safe sir
Sat Dec 19, 2015Post  #1
ANISH
ANISH
Plan for above said case
Attachments: 1.png Sat Dec 19, 2015,&n
Sat Dec 19, 2015Post  #2
Dear Anish
         In my view it is better to consult any civil / structural engineer for this problem, who will guide after inspecting the site.
Thu Dec 24, 2015Post  #3
Beam is needed for any load above and no support below.
Safety Tips-Construction Questions (20)
10056
1766
2531
2435
RCC ROOF Requirements
Last answer on 5/22/2013 8:47:10 AM. by Rajesh. Forum started by Rajesh
3615
4950
HOLLOW CORE CONCRETE SLABS
Last answer on 11/17/2009 12:39:06 PM. by Girish. Forum started by Girish
9906
4068
2868
Steel calculation
2621
COLUMN nd LOAD BEARING
7271
2077
Weight on Sump Tank
Last answer on 2/3/2021 11:35:35 PM. by JAI PRAKASH. Forum started by awdhesh
9586
Last answer on 10/17/2016 1:19:41 PM. by Vishal Thakur. Forum started by Vishal Thakur
2156
Sunken slab
Last answer on 1/17/2021 5:51:16 AM. by freekundli. Forum started by Bhaskara
2566
4065
4024
labor rate for RCC work
8855
Last answer on 10/15/2014 1:52:38 PM. by SANJAY DUSANE. Forum started by Ambuj
3946
3506
Specification of Steel
Reasons of dampness
Advantages
Copyright 2007- 2024 GharExpert.com All rights reserved.
