Home -> Forums -> Construction -> Start Construction -> SLAB REINFORCEMENT
Wed Apr 13, 2016Total posts : 1
Topic: SLAB REINFORCEMENT
IN SLAB WHICH STEEL IS UP AND WHICH STEEL IS DOWN...IN CASE OF MAIN STEEL OR DISTRIBUTION STEEL? AND WHY?
Wed Apr 13, 2016Post  #1
Dear Mada
          The main MS Steel bars are laid first i.e. down words and these are on the shorter span/ distance as these have to take load and make slab safe against tensile stress. The distribution steel bars on above main bars to hold main bars in position and increase the bond strength. For more detail see link below
http://www.gharexpert.com/tips/articles/Construction/1730/Cement-Concrete-1730-Mild-Steel-Bars-in-Cement-Concrete_0
http://www.gharexpert.com/tips/articles/Construction/1753/Cement-Concrete-1753-Centering-Shuttering--Form-Work_0
1831
3312
1176
4012
labor rate for RCC work
1401
1503
1256
2125
CRACK IN CENTRE OF SLAB
1508
TORSION REINFORCEMENT
Last answer on 4/15/2016 2:02:52 PM. by S L Gupta (Civil Engg). Forum started by ANKITA MADA
6471
2564
Specification of ‘Plastering’
2377
1846
SLAB LOADING
Last answer on 12/24/2015 4:05:10 AM. by JAI PRAKASH. Forum started by ANISH
9894
2866
Steel calculation
1657
2563
4057
3312
2236
2312
2061
Reasons of dampness
Centering
Advantages
