Home -> Forums -> Construction -> Start Construction -> SLAB REINFORCEMENT
Thu May 05, 2016Total posts : 2
Topic: SLAB REINFORCEMENT
IN SLAB, WHICH STEEL(MAIN OR DISTRIBUTION) NEED TO ALTERNATE BENT UP? AND WHY?
Thu May 05, 2016Post  #1
Dear Ankita
          The main steel bars are alternately bent up at the end supports for protecting the slab from compression stress in single way design. For double way design both side bars are main  bars and bent up alternately at the supports.
Mon May 09, 2016Post  #2
THANKS SIR.
1782
Last answer on 4/13/2016 1:01:09 PM. by S L Gupta (Civil Engg). Forum started by ANKITA MADA
3285
1157
3986
labor rate for RCC work
1244
1389
1486
2116
CRACK IN CENTRE OF SLAB
1497
TORSION REINFORCEMENT
Last answer on 4/15/2016 2:02:52 PM. by S L Gupta (Civil Engg). Forum started by ANKITA MADA
6442
2359
2539
Specification of ‘Plastering’
1820
SLAB LOADING
Last answer on 12/24/2015 4:05:10 AM. by JAI PRAKASH. Forum started by ANISH
4049
9848
2848
Steel calculation
1642
2140
Sunken slab
Last answer on 1/17/2021 5:51:16 AM. by freekundli. Forum started by Bhaskara
2550
2451
3274
3285
4429
3975
2199
2702
4212
5169
2379
2294
1997
2448
2114
3195
2048
12515
2164
2727
Reasons of dampness
Centering
Advantages
