Home -> Forums -> Construction -> Start Construction -> SLAB REINFORCEMENT
Mon May 09, 2016Total posts : 3
Topic: SLAB REINFORCEMENT
IN CERTAIN SLABS, SOME ENGINEERS GIVE A DOUBLE MESH SLAB DESIGN.WHAT IS A DOUBLE MESH SLAB DESIGN AND WHERE DOUBLE MESH IS REQUIRED AND WHY?
HOW THE ARRENGEMENT OF DOUBLE MESH REINFORCEMENT?
GIVE FIGURE OR SECTION.(IF POSSIBLE)
Tue May 10, 2016Post  #1
Dear Mada
     I do not follow your point about double mesh.
Tue May 10, 2016Post  #2
DOUBLE MESH PROVIDED IN DESIGN OF WATER TANK WHICH IS ON THE TERRACE.
Wed Jun 26, 2019Post  #3
          Thanks for visiting the site.
Start Construction-Construction Questions (38)
1788
Last answer on 4/13/2016 1:01:09 PM. by S L Gupta (Civil Engg). Forum started by ANKITA MADA
1832
1178
4016
labor rate for RCC work
1403
1505
1257
2125
CRACK IN CENTRE OF SLAB
1509
TORSION REINFORCEMENT
Last answer on 4/15/2016 2:02:52 PM. by S L Gupta (Civil Engg). Forum started by ANKITA MADA
6471
2566
Specification of ‘Plastering’
2377
1847
SLAB LOADING
Last answer on 12/24/2015 4:05:10 AM. by JAI PRAKASH. Forum started by ANISH
9894
2867
Steel calculation
1657
2564
4060
3298
2236
2717
5198
2315
2015
2136
3210
2063
12531
Reasons of dampness
Centering
Advantages
