Home -> Forums -> Construction -> Brick Walls, Pillars and Structure -> STEEL BARS IN 4.6 INCH WALL
Wed Feb 04, 2009Total posts : 2
pooja
pooja
Topic: STEEL BARS IN 4.6 INCH WALL
IS IT NECESSARY OR ADVISABLE TO PLACE STEEL BARS IN 4.5 INCH PARTITION WALL? IF SO AT WHAT HEIGHT AND INTERVALS AND WHAT SHOULD BE THE DIA OF BAR.
Wed Feb 04, 2009Post  #1
Deepti
Deepti
Post subject: Using Steel Bars in 4.5 Inch Wall
It is not clear that 4.5 inches partition wall is to be made as brick wall or R.C.C. partition wall.  However, I am taking both cases as follows.
1. Brick partition wall 4.5 Inches thick.
A) If the height of wall is not more than 7 feet, the length of wall is not more than 10 feet and no door and window is provided in the wall,   there is no need to provide any steel bars. These walls are called 4.5 inch thick wall without hoop iron.
B) Hoop Iron wall: If 4.5 inch thick partition wall having different specifications stated above, Hoop iron should be provided in walls as under.
  • The size of mild steel flat strips should be 25 mm wide, 1.2 mm thick or 18 gauze should be provided at every fourth course of brick wall i.e. about after 1 feet interval.
  • These Mild Steel flat strips should be embedded in cement mortar with coarse sand 1:4.
  • Care should be taken that Mild Steel flat strips should be completely embedded in cement mortar and does not touch bricks at any place.
  • If Mild Steel flat strips touch bricks, there is every possibility of rusting the Mild Steel flat strips which may cause cracks in long run.
2. R.C.C. partition wall 4.5 Inches thick
If you are constructing 4.5 inch thick R.C.C. partition wall, use 10 mm dia Mild Steel Bars, 6 inch centre to centre both ways and use cement concrete 1:1.5:3.
Thu Feb 05, 2009Post  #2
pooja
pooja
Thanks Deepti thanx for providing me such a valuable information.
2899
RCC Roof
2121
Baathroom design required
Last answer on 6/12/2019 12:58:56 AM. by woodrowb997. Forum started by Rohit
1304
1632
3059
steel formula
Last answer on 4/16/2014 8:05:15 PM. by shaik khaja nayab rasool. Forum started by shaik khaja nayab rasool
13774
overlap length to steel
1657
2091
Foundation
13756
2037
2708
2304
2034
3108
1273
1530
1256
Is HYSD steel bars still used for construction. Do they meet the safety standard
Last answer on 1/10/2019 12:18:04 AM. by S L Gupta (Civil Engg). Forum started by rinu
5812
3793
9885
2670
4628
4143
2866
5008
3657
1865
2801
2610
2374
2463
2638
1808
3608
6254
Type
HSD
TMT
Precautions
Dining
Dining Chairs and Bar Stools
