Home -> Forums -> Construction -> Foundation -> STEEL BEAM & COLUMN
STEEL BEAM & COLUMN
Mon Jan 11, 2016Total posts : 1
DURJOU KUMAR MONDAL
DURJOU KUMAR MONDAL
Topic: STEEL BEAM & COLUMN
DEAR Sir,
My plan is 55 feet x 35 feet for 1st to 3rd floor will be same,where ground floor will be FOR 28 X 48 sft free from any room.My requirement is that how many column & beam will be required for that plan & what type of steel required for column & beam.
Pl see the attachment to see my plan where mentioned the side.
Please advise me & don't wrote me that "please you contact our ghar expert or any other's engineer's suggestion "
Durjoy kumar
9933021800
Attachments: PROJECT OF 1ST TO 3RD FLOOR.xlsx on Mon Jan 11, 2016,&n
Tue Jan 12, 2016Post  #1
Check with your architect. We have already given you the idea for the same.
2039
2712
2306
2039
13808
overlap length to steel
4942
COLUMN AND STEEL DESIGN
4942
15615
2724
2708
1317
3725
2658
Cost of construction of roof slab.
Last answer on 9/13/2013 11:42:05 AM. by feroz khan patthan. Forum started by suhas
65248
1371
1624
Residential Structural needs
Last answer on 10/5/2016 12:15:38 PM. by S L Gupta (Civil Engg). Forum started by Padmanabhan
1997
2691
Pillar
2144
Curing urgent
2381
structure work
5169
Pillar foundation
2214
new house
2823
building a house
1994
Construction Agreement
3092
Foundation
2275
Foundation
1480
10058
3667
Foundation
2120
Structure proof checking
2565
Foundation design
2466
2471
Saria and cement
3659
Wall Thickness
2682
3191
13272
Steel Type
Centering
Type
HSD
Precautions
Steel
Steel Roofing
