Home -> Forums -> Construction -> Start Construction -> Sand and Cement
Sand and Cement
Sun Aug 16, 2015Total posts : 1
gurudatt1825
gurudatt1825
Topic: Sand and Cement
Dear Experts,
I am starting my house construction in Bangalore. i have the below queries, please provide your expertise
1) I am going for M sand. Which branded M sand supplier is good in Banaglore.
2) Is it better to mix M sand and river sand and use or is it safe enough to use M sand alone?
3) whether to go with 53 grade cement or 43 grade cement
4) Planning to consider coromondal cement. whether Coromondal cement is equally good as Birla super?. i see there is difference of around 25 rs per bag between these two brands.
Mon Aug 17, 2015Post  #1
      You should check sand for the specification given below
Fine aggregate/ coarse sand consists of natural sand, crushed stone sand or crushed gravel stone dust. It should be hard, durable chemically inert, clean and free from organic matter, not containing any appreciable amount of clay balls or pellets and other harmful impurities i. e. alkaline, salt, mica, decayed vegetation, lumps etc.
It should be passed through I. S. Sieve 4.75 MM. It should have the finest modulus 2.50 to 3.50 and silt contents should not be more than 4%. Coarse sand should be either river sand or pit sand; or combination of the two.
Note: In general the sand particle should be coarser and have minimum silt contents. The silt contents should not be more than 4%.
Caution:
The quality of the sand has more impact on the strength of the structure inspite of the quantity of the cement used.
1) If there is more silt in coarse sand, the strength of cement mortar is reduced from 1 % to 30%.
2) If you take best quality coarse sand, it will give maximum strength.
Quality of Coarse Sand
Actual specification for the quality of coarse sand can be obtained by laboratory test but in general we can judge the quality of coarse sand in the field through the following ways.
1. Observe whether there are any lumps of earth or clay balls, grass and decayed vegetation etc. in coarse sand to check silt contents.
2. Take some samples of coarse sand in hand and observe
The particles of sand should be coarser.
Silt contents should be less
3. Take some sand in hand and drop it down
One can simply check the quality of sand by taking some sand in the hand and then dropping it down.  If some finest material sticks with hand, the sand has some silt contents and finer sand.
4. Check silts contents with the help of water
Take empty glass and put some sand and water in the glass and stir it well. After some time the silt layer will be framed between sand and water which shows the quantity of the silt contents present in the sand.
For cement 43 grade is good. use branded factory manufactured cement not for plant manufactured cement.
1747
1443
3756
3261
For Estimate
13719
2048
cement : sand:stone ratio
4351
WHAT IS THE RATIO
2848
3478
1495
And how much is labour and material cost to chip old wall and replaster it with
Last answer on 11/8/2017 1:53:56 AM. by S L Gupta (Civil Engg). Forum started by Sheila
3580
3686
1998
coarse aggregate
4053
Forumula to calculate
Last answer on 7/3/2009 1:18:44 AM. by Priti Arora. Forum started by Anandan
2024
Estimate
1656
Last answer on 5/3/2016 12:13:14 AM. by JAI PRAKASH. Forum started by sayeedmohsin
2662
2290
Sand units
1681
Sand units
2451
3273
3284
4429
3975
2196
2699
4210
5167
2378
2294
1996
2447
2114
3194
2046
12514
2164
2010
2726
