Home -> Forums -> Construction -> Plumbing -> Sand in Water
Sand in Water
Thu Dec 04, 2008Total posts : 1
Kanhaiya
Kanhaiya
Topic: Sand in Water
I am in rural Gujarat, India. We constructed a new house. First time, cheap water pump was used. The output of water wasn't good. There was a question net type filter being applied during the boring. Some people said put that filter on, some people said not needed.
After replacing the cheap water pump with a better quality one. We are getting water. But it has Sand in it. Making the water undrinkable. What can be done to solve the problem? Or is the Sand in Water for short period then the water will be clean,
Is there a special filter that has to be fitted? What brand? Where to place it? A picture would be nice.
Thanks in advance!
Thu Dec 04, 2008Post  #1
yogiagarwal
yogiagarwal
Post subject: How to get clean water from bore well?
It seems that bore well is not fully developed at the time of fixing water pump. Also the gravels are not filled around casing pipes as additional precaution so that mud and sand do not enter the perforated pipes with water when the pump is operated.
Now, to develop bore well operate pump continuously at least for 10 to 12 hours with small intervals. After the development of bore well you will get clean water and the water will be cleaner with the passage of time.
It is also advisable to take help of local tube well fitter who deals with setting up of tube wells, water pumps etc.
3712
2011
coarse aggregate
1762
1456
pile work
2101
river sand
2327
Sand units
1706
Sand units
1525
Sand units
1870
suggest for exterior
3008
M-Sand for Plastering
16072
robo sand vs natural sand
6450
2241
sand alternate for concrete
3148
Last answer on 7/3/2020 9:54:13 PM. by S L Gupta (Civil Engg). Forum started by padmaraju
1697
I like this picture plese sand me plan
Last answer on 8/4/2014 11:18:58 AM. by seema tyagi. Forum started by sandy
1781
what is sand blasting in fabrication work
Last answer on 10/4/2014 12:33:58 PM. by S L Gupta (Civil Engg). Forum started by SANJAY DUSANE
1533
can sand blasting is possible at site
Last answer on 10/5/2014 11:38:19 PM. by JAI PRAKASH. Forum started by SANJAY DUSANE
6271
Water Tank Quality
3114
Hot Water Tank
3380
Diverters for Bathroom
2561
2145
40516
2083
GI pipe Vs CPVC pipeline
2931
1755
2080
Toilets
1988
Wall mounted cummod vs normal
5055
2775
2388
1855
3074
Swimming pool
2541
water softner
2682
commode type and flush type
4193
to shut off water to house
60
60 Tips to Save Water
Vastu for Water Tank
Water for Construction
Rain
Rain Water Harvesting
Preventive
