Home -> Forums -> Construction -> Fine Sand -> Sand units
Sand units
Thu Jan 05, 2017Total posts : 1
Pasha
Pasha
Topic: Sand units
Here in my city they are selling sand in Units.Can you explain  what does this meaning of Unit and how to calculate 1 unit of sand
Fri Jan 06, 2017Post  #1
Dear Pasha,
     In technical/ engineering sand unit are cubic feet or cubic meter. It means length x width x height.
Fine Sand-Construction Questions (27)
1706
Sand units
1525
Sand units
66828
just want to know what is CUM ( unit )..and who we can find this unit ..suppose
Last answer on 9/23/2021 3:52:35 AM. by S L Gupta (Civil Engg). Forum started by sohail
3713
2012
coarse aggregate
1767
1460
2550
Factory Main Door
2945
Can I get 300cm long tv unit
Last answer on 8/16/2018 12:51:10 AM. by S L Gupta (Civil Engg). Forum started by sadekhussin
24852
greeting cards display unit
Last answer on 2/18/2021 10:26:55 PM. Forum started by archi verma
2475
i want to see the front &back view of this wall unit with its cabinet uses
Last answer on 7/3/2020 10:26:24 PM. Forum started by jyoti agrawal
2834
Am looking out for some latest designs of TV units and portrait display tables
Last answer on 7/9/2021 7:38:00 PM. Forum started by RVkamat
2346
what material use in wall unit
Last answer on 5/31/2012 4:15:46 PM. Forum started by sonali
2876
Last answer on 5/31/2012 4:16:57 PM. by Gunjan Utraja. Forum started by sonali
1624
2746
2102
river sand
16073
robo sand vs natural sand
3009
M-Sand for Plastering
2193
1706
Sand units
1525
Sand units
3009
16073
2035
Alternate for River Sand
Last answer on 2/25/2013 2:02:46 PM. by RENJI. Forum started by RENJI
2810
sand wight per cu.feet
Last answer on 11/5/2012 11:47:35 AM. by S L Gupta (Civil Engg). Forum started by aammiitt
3526
alternative for river sand
Last answer on 6/11/2011 9:17:04 AM. by S L Gupta (Civil Engg). Forum started by sudakar
Air
Air Conditioner AC: Tips before buying Air Conditioners
Check out GharExpert buying guide for Air Conditioners AC so that you could know about different types of Air conditio..
Glass
Glass Shower Enclosure
Today people are using shower enclosure in their bathroom to make it look elegant. To create a feeling of openness and..
Swimming
Swimming Pool Filters
