Home -> Forums -> Construction -> Foundation -> Saria and cement
Saria and cement
Wed Mar 25, 2015Total posts : 1
ARVIND GOYAL
ARVIND GOYAL
Topic: Saria and cement
plz tell me
any qualitywise difference between
TATA STEELS and KAMDENU
and between ACC and ULTRATECH cement.
As per my knowledge i want to use TATA STEELS and ACC but these are not available nearby. So i have to opt for KAMDENU Saria and  ULTRATECH cement.
Thu Mar 26, 2015Post  #1
Use Kamdhenu 10000 which is equal to TATA Tiscon, Normal kamdhenu is made up of scrap.
Foundation-Construction Questions (38)
2924
How Many Bricks, Cement or Saria Require for 1350 Square ft Plot
Last answer on 1/15/2015 10:42:09 PM. by JAI PRAKASH. Forum started by nitin
3076
RCC roof
3792
1890
Regarding Roof Load on Pillar
Last answer on 9/28/2015 12:49:09 PM. by S L Gupta (Civil Engg). Forum started by Amit Kumar
2160
4212
Selection of cement ..
1923
2410
what are these 3 types
2695
1767
1460
1659
Last answer on 7/15/2017 12:48:17 AM. by S L Gupta (Civil Engg). Forum started by Frank lun ngaihte
3075
1742
3992
1785
1876
Last answer on 11/3/2016 10:40:18 AM. by S L Gupta (Civil Engg). Forum started by shashi
2967
Tips for Cement Paint
2082
Last answer on 10/23/2010 3:33:17 PM. Forum started by sandeep Dholakia
2684
Pillar
2140
Curing urgent
2372
structure work
5166
Pillar foundation
2204
new house
2821
building a house
1992
Construction Agreement
3091
Foundation
2272
Foundation
1476
10048
3660
Foundation
2115
Structure proof checking
2558
Foundation design
2462
3657
Wall Thickness
2679
3179
13267
Steel Type
Cement Concrete Raw Material
Read points should be kept in mind while collecting raw materials for cement concrete in construction work.
Types of Cement
