Home -> Forums -> Construction -> Brick work -> Seepage into home from external wall
Wed Aug 01, 2012Total posts : 1
P. Panchal
P. Panchal
Topic: Seepage into home from external wall
can we stop water seepage from external wall.  the wall is 8 inch thick and also it is plastered from outside. my first question is - what can we do now to stop seepage.
my second question is- what precautions to be taken while making new wall to avoid this seepage.
Sat Aug 04, 2012Post  #1
Dear Panchal
                 Dismentle the tile of roof with the wall, lay the cement concrete gola with wall and lay again the tiles and finsh the roof again.Care should be taken that there should proper slope on the roof so that there should be proper drainage.
1699
In East facing home the external stairs for enterance on North East is good or n
Last answer on 11/16/2017 10:34:49 PM. by S L Gupta (Civil Engg). Forum started by Deepshikha Jaiswal
2079
2366
estimation
2045
I had constructed 4" inch wall on the external wall on the first floor what prec
Last answer on 6/26/2019 10:39:50 PM. by S L Gupta (Civil Engg). Forum started by Badhavath Rajeshwar
2438
how to avoid rain water seepage in 4 inch brick wall any suggestion?
Last answer on 5/21/2015 5:29:55 PM. by JAI PRAKASH. Forum started by ashok
2079
outside side wall with 4.5 inch width is suggested or not ? will it cause seepag
Last answer on 7/4/2020 2:24:25 AM. by JAI PRAKASH. Forum started by ashok
27
Rain Seepage from outer wall
Last answer on 4/5/2011 9:16:46 PM. Forum started by Dr Akshay
2219
2112
2196
PLEASE SEND ME NEW DESIGN FOR HOME WALL & ROOF 10X12 ROOM
Last answer on 10/18/2013 4:07:28 PM. by S L Gupta (Civil Engg). Forum started by PRAKASH KUMAR
2242
1381
I want external stair design
Last answer on 4/2/2016 11:25:11 AM. by S L Gupta (Civil Engg). Forum started by pushpak
1998
best designs for external stair cases
Last answer on 9/20/2021 12:33:21 PM. by JAI PRAKASH. Forum started by rambo fernandes
3237
I want to paint my house plz suggest the colour for internal rooms & external
Last answer on 2/15/2012 10:39:54 PM. by skycrane. Forum started by vago suzare
2025
for south facing site external staircase should be in whitch direction
Last answer on 12/12/2010 1:15:56 AM. Forum started by KALAIVANI
2275
wall cladding
Last answer on 7/2/2020 9:46:33 PM. by S L Gupta (Civil Engg). Forum started by ismail
1868
Paint
Last answer on 2/15/2022 5:52:44 AM. by S L Gupta (Civil Engg). Forum started by chethan
2767
3539
Is it ok to have,as per vastu, curved outer walls for homes especially if it is
Last answer on 8/31/2011 8:43:43 PM. Forum started by Mathew George
3674
wals
3268
compound wall
21928
3285
Bedroom Wardrobes information
2251
2216
1502
1974
1737
2231
2530
1507
1914
Brick or ACC block
2028
1662
2154
1710
4735
Brick wall on RCC slab
3938
2624
Hardwood
Hardwood door
Hardwood
Hardwood window
Canvas
Canvas Wall Art
A
Wall
Wall Decor
Home Decorating Tips
Your home is a place where you live, dont make it a workplace, dont mess up. Decorate your home in unique style. Use w..
Paint
