Home -> Forums -> Construction -> Basement -> Selection of cement ..
Sun May 07, 2017Total posts : 1
PRAVEEN G
PRAVEEN G
Topic: Selection of cement ..
Is it good to use PPC cement for basement (ACC Suraksha)..
Please suggest the best cement that to be used in different stages of construction like basement, walls, columns,beams, plastering etc..
Mon May 08, 2017Post  #1
Types of Cement
For engineering purposes, there are many types of cement but in general, ‘Ordinary Portland Cement’ (OPC) which is available in three grades should be used for house construction
33 Grade Ordinary Portland Cement
This ordinary 'Portland' cement is used maximum in the country. It is more suitable cement for masonry and general concrete works where the members are not taken to very high stresses. It is not suitable where ‘Sulphate’ is in the soil or in the ground water.
 43 Grade Ordinary Portland Cement43 grades of cement are used where high early strength in 1 to 28 days range is required. These days the ‘Structural Engineers’ propose these cements mainly for RCC works where a member takes high tensile stress.
53 Grade Ordinary Portland Cement
53 grades of cement are used where high early strength in 1 to 28 days range is required. These days ‘Structural Engineers’ propose these cements mainly for RCC works, where a member takes high tensile stress.
Caution in the use of 53 grade cement in construction:
The strength of 53 grade cement does not increase much after 28th day because of early gain while 33 grade cement continues to gain strength after 28th day.
In addition, due to faster hydration process, the concrete releases heat of hydration at much faster rate initially and release of heat is the highest in case of 53 grades. The heat of hydration being higher, the chances of micro-cracking of concrete is much greater. Thus during initial setting period of concrete, the higher heat of hydration can lead to the damage of micro-cracking within the concrete which may not be visible at surface.
This cracking is different from shrinkage or cracks which occur due to faster dryness of concrete in windy conditions. The situation can be worse when we tend to increase the quantity of the cement in concrete with a belief that such increments are better for both strength and durability of concrete.
Thus it is very essential to be very careful in advance that higher grade cement specially GRADE 53 SHOULD be used only where such use is warranted for making the concrete of higher strength and also where good quality assurance measures are in place by which proper precautions are taken to relieve the higher heat of hydration through chilling of aggregates or by proper curing of concrete
Various Colors of Cement
1. Grey = Color of OPC cement
2. Blackish = Color of PPC Cement
3. White = Other color of Cement
Various Brands of Cement
1. ACC
2. J.K.( Shakti Laxmi)
3. Birla ( Chetak Mehar ,Uttam, Khauraho, Manglam)
4. Shree
5. Prism
6. Dig Vijay
7. Ambuja
8. CCI
9. Vikram
10. Jay Pee Rewa
11. Binani
12. Shri Ultra
13. L. & T.
Specification of Cement
The cement required for construction should be factory-manufactured from a reputed manufacturer. It must not be from the local plant manufacturer. Care should be taken that the cement is properly packed from the factory, not be hand packed locally. While taking supply of cement manufacturing date, grade and type should be checked. The cement should not be more than six weeks old from the date of manufacturing.
Precautions While Purchasing Cement
Cement is the most important raw material used in a building. You should ensure the quality of ‘Cement’ using the following guidelines.
1. The cement should be factory manufactured instead of plant manufactured.
2. The cement should be packed in the bags of synthetic jute or polypropylene bags.
3. The cement bags should not be hand stitched.
4. The cement bag should bear manufacturer's name or his trade mark on it if any.
5. The cement bag should bear the grade and type of cement.
6. The cement bag consignment must have identification mark on package.
7. The cement bag should indicate the date of manufacturing.
8. One cement bag should have 50 Kg. weight.
9. The cement bags should not be older than six weeks from the date of manufacturing.
10. Do not purchase cement bags which are partially set due to moisture. Do not purchase if there are small lumps in the bags.
11. Do not purchase cement bags which are pressed or have lumps due to high pressure of stack having more than 10 to 12 bags.
12. Do not take cement bags which are torn by side and stitched in later.
Precautions While Transporting Cement Bags
1. Care should be taken to carry the bags in a clean vehicle which is not dustier or on earth etc. It will reduce the strength of the cement.
2. During monsoon season the cement should be carried under covered Polythene or ‘Tarpaulin’.
3. Care should be taken that the labor should not tear the bags while loading and unloading the cement bags.
Precautions While Stacking Cement at Site
Store cement in a moist proof storage area other wise quality of cement will be affected.
1. Cement should be stacked in a shed/fumes, which is dry, leak proof and moisture proof.
2. Cement should be placed on dry brick floors, on wooden crates or on the planks.
3. In any case, the cement bags should not be stored on the earth.
4. The stack should not be higher than 10 bags to avoid lumps under pressure.
5. The cement bags should not be stacked with outer wall.
6. Cement from different manufacturers should be stacked separately.
7. The cement should be used on first come first used basis.
8. During monsoon season cement bags should be covered with polythene.
9. The cement bags should be kept close together to reduce air circulation.
Caution:
1. When construction work is given to a contractor, make sure he takes proper care of the cement. A lot of time contractors do not care for proper storage of the cement at site as it costs them labor time (money).  This results in reduction of strength of cement as the table below shows.
2. In some cases it has been seen that after laying the RCC slab on some part of the building, the contractor dismantles his temporary store at the site and places cement on ground floor of the building which is under construction. This is not good as the cement bags may draw moisture from the floor and walls, as the new building is wet due to construction work in progress, which results in reduction of strength in cement.
Reduction in Cement Strength Due To Storage
  S. No  Storage Period  Reduction in Strength
 1  Fresh cement  Nil
 2  Three months old  20%
 3  Six months old  30%
 4  12 Months old  40%
 5  24 Months old  50%
1. Due to absorption of moisture by cement during storage, cement retards in hardening and reduces the strength.
2. It is okay for cement to absorb up to 1.2% moisture as this level of moisture is acceptable but if absorption exceeds 5%, the cement is destroyed for all practical purposes.
3. Different types of cements should not be mixed while using them for constructional purposes.
Basement-Construction Questions (38)
1931
2266
Cement selection
2308
Cement selection
Last answer on 10/31/2012 10:53:57 AM. by amzad. Forum started by amzad
1697
what should be the criteria for selection of house in a society, should one go f
Last answer on 12/31/2020 2:12:04 AM. by Priti Arora. Forum started by puneet
543
A trustworthy torrent site - which one to pick?What are the selection criteria?
Last answer on 1/5/2022 9:16:55 PM. by olii fill. Forum started by CrySmile
3792
1923
2409
what are these 3 types
2695
1767
1460
1659
Last answer on 7/15/2017 12:48:17 AM. by S L Gupta (Civil Engg). Forum started by Frank lun ngaihte
2405
3074
2123
I have read your articles regarding the strength of fresh cement,and how cement
Last answer on 9/13/2012 5:19:43 PM. by S L Gupta (Civil Engg). Forum started by George Kattapuram
1741
2909
Shuttering Plywood
Last answer on 11/17/2009 9:26:16 AM. by Girish. Forum started by Girish
2967
Tips for Cement Paint
2082
Last answer on 10/23/2010 3:33:17 PM. Forum started by sandeep Dholakia
9061
makan map
2774
17223
1993
2157
design of column
2282
2253
Underground water tank
2658
2764
foundation
2033
Full Plan Needed
3196
labour cost
3163
APP membrane
2798
1970
ffff
1872
3465
2016
Regarding construction
3154
Basement Water proffing
2015
Acid staining
How to select Mason
For all type of construction, weather new or alteration, Mason is a very important and selection of a mason is not a b..
Selection of Cushion Covers
Cushion covers are a great bonus to the interior of a home. They cover up your cushions and can superbly change the lo..
Types of Cement
