Home -> Forums -> Construction -> Drainage , Sanitary System and Plumbing -> Septic Tank Design
Septic Tank Design
Mon Apr 29, 2013Total posts : 2
Jitender Suhag
Jitender Suhag
Topic: Septic Tank Design
Dear Expert ,
I need Advise on Septic Tank Design
1 What should be the volume ( dimension ) for family of 4 and only for toilet waste.
2 should i go for plaster ( water proof) from bottom or i should leave it soak pit , if soak pit what should i use at bottom only soil , or bricks pieces , if it soak pit then over flow pipe should be inserted or not
Thanks in Advance
Tue Apr 30, 2013Post  #1
Dear Suhag
       The size of septic tank is 5' x 3' and 3.5' its liquid depth.
2. Bottom should have brick ballast and insert over flow pipe.
See the link below. In subsection of soil waste drainage see about septic tank.
http://www.gharexpert.com/articles/Soil-Waste-Drainage-Sewage--1817/Septic-Tank,-It%E2%80%99s-Principle-Guidelines_0.aspx
Tue Apr 30, 2013Post  #2
Jitender Suhag
Jitender Suhag
Dear Gupta,
Thanks Very Much for suggestion
3037
Last answer on 4/1/2013 3:23:48 PM. by akmurty1. Forum started by kjeevanrao
2827
What is the right place for septic tank
Last answer on 5/27/2019 1:04:59 AM. by sathish. Forum started by anoop
2673
septic tank location
Last answer on 9/18/2010 12:27:53 PM. Forum started by kamal
2141
my septic tank in dining hall
Last answer on 4/30/2011 9:39:07 PM. by S L Gupta (Civil Engg). Forum started by rohitraj
2277
I have septic tank in SW. What is remedies
Last answer on 1/2/2021 5:27:45 AM. by Pavan. Forum started by sunil
2095
Vastu for septic tank
Last answer on 7/19/2013 1:38:06 PM. by S L Gupta (Civil Engg). Forum started by Iswarya.N
2105
where septic tank is good in east facing house
Last answer on 10/28/2017 2:01:08 AM. by Shailendra Srivastava. Forum started by akshay
958
east facing one side plot septic tank loction
Last answer on 7/3/2020 10:54:55 PM. by S L Gupta (Civil Engg). Forum started by Bhagchand Chhipa
1852
1913
Last answer on 10/7/2020 10:22:43 PM. by S L Gupta (Civil Engg). Forum started by siva
1599
IS THERE ANY DIFF. IN CONSTRUCTION CHARGES WITH MATERIAL FOR MUMTY , SEPTIC TANK
Last answer on 10/20/2016 12:44:55 PM. by S L Gupta (Civil Engg). Forum started by ANIL AGRAWAL
1875
reg-septic tank
Last answer on 7/1/2013 4:35:26 PM. by S L Gupta (Civil Engg). Forum started by john bosco
2568
septic tank or sum
Last answer on 6/9/2021 9:43:39 PM. by JAI PRAKASH. Forum started by rohith shetty
2206
My house is under construction kindly advice the position of septic tank.Option
Last answer on 9/7/2010 5:46:10 PM. by sabina vanjani. Forum started by piyu sur
3385
according to vastu where should septic tank should be place..??
Last answer on 7/29/2009 11:39:05 PM. by Veena Gil. Forum started by priyanka
2842
I am constructing a house in north face plot please send right position of septi
Last answer on 3/31/2012 8:53:58 PM. by J J Gupta. Forum started by J J Gupta
6663
How to Build Septic Tank for house
Last answer on 9/20/2012 5:51:39 PM. by PR Jawahar. Forum started by P. Panchal
2160
please give some suggestion, that we have onely4square feet land in the middle o
Last answer on 8/27/2012 3:33:59 PM. Forum started by Jagajothi
1618
Sir,According to my house plan, I have to construct 3 nos of pillars inside my h
Last answer on 10/8/2020 11:50:18 PM. by S L Gupta (Civil Engg). Forum started by nihar hota
1890
tap Connection
3633
sunken slab
2510
How to hire a plumber
3504
1678
2328
3866
flush toilet
1964
4728
Cost estimation for sump tank
2227
water supply
2047
Underground Water storage
sewage pipes
2256
commode & flush type
1953
WC issue
5637
Over-Head water Tank
2345
2487
3394
3762
Vastu for Water Tank
Preventive
Porch
Porch Designs
Reasons of dampness
Sewerage
Sewerage & Plumbing System
