Home -> Forums -> Construction -> Waste Water Drainage -> Sewage and drainage lines
Wed Nov 21, 2012Total posts : 1
Shafeeq Chaduhary
Shafeeq  Chaduhary
Topic: Sewage and drainage lines
My home area is 600 square yard. On the backside there is 50 feet then
it will turn towards outside and need pipe about 90 feet. Total length is 140 feet.
It is a double story house each floor will have 4 Bath rooms and one kitchen.
I need to know what will be the slope of each pipe and size.
Better to run two separate pipe one for drainage and one for foul sewage line.
Do I need to keep access points. Normally how far an access point is kept?.
With best regards,
Shafeeq
Mon Dec 10, 2012Post  #1
Dear Shafeeq
In sewer line minimum gradient should be 1 in 57 for 100 mm diameter pipe and 1 in 100 for 150 mm diameter.For more information please see the link given below
http://www.gharexpert.com/articles/Waste-Water-Drainage-1793/Guidelines-Plumbing-Sewerage-Pipe-Works_0.aspx
Waste Water Drainage-Construction Questions (25)
4076
drainage pipe line for toiletfor south facing house
Last answer on 1/19/2022 6:35:06 AM. by S L Gupta (Civil Engg). Forum started by ajitkumar
3449
how to line out work to residential building
Last answer on 7/4/2020 2:18:55 AM. by S L Gupta (Civil Engg). Forum started by patil kiran
2188
Last answer on 11/18/2013 10:57:21 AM. by S L Gupta (Civil Engg). Forum started by adari haripraveen
1918
Last answer on 11/18/2013 10:38:53 AM. by S L Gupta (Civil Engg). Forum started by adari haripraveen
2074
vastu guide lines for cellar
Last answer on 3/20/2011 1:25:50 PM. Forum started by DURAISWAMY.G
2195
can sewerage line be lying in south west corner of house
Last answer on 3/28/2012 11:42:26 PM. by Priyanka Sharma. Forum started by vkgogra
1771
2330
3 doors in one line
Last answer on 6/22/2017 11:11:23 PM. by S L Gupta (Civil Engg). Forum started by Amol Wadkar
1719
Inverter /solar line safety
Last answer on 6/17/2021 12:00:43 AM. Forum started by Sajeev
71
Need Help
Last answer on 1/28/2011 10:06:57 AM. by Nikita. Forum started by abid_baig@yahoo.com
1752
I have read that there shouldnt be three doors in a single line.Is it true?
Last answer on 9/26/2009 5:23:19 AM. Forum started by Amol Pathare
1958
2262
is it necessary to have the centre of gate and that of main door in the directio
Last answer on 1/2/2021 5:22:29 AM. by Nikita. Forum started by D.Ramachandran
2680
My House design
1680
Dear sir my house construction is going very well but my house front side EB pow
Last answer on 10/12/2015 10:30:39 AM. by S L Gupta (Civil Engg). Forum started by balamurugan
2931
2231
sewage pipes
3471
right direction for sewage & other waste pipelines from a east facing house
Last answer on 5/7/2010 2:01:23 PM. by ankur. Forum started by ankur
2141
Need your guidance
Last answer on 8/20/2012 12:27:18 PM. by S L Gupta (Civil Engg). Forum started by sam_m400
2030
whats remedy fr wall dampnass
Last answer on 2/25/2022 7:03:51 AM. by helloaarti21. Forum started by rakesh chopra
3291
2763
2000
please help....slow draining in the bathroom
Last answer on 7/4/2020 2:24:02 AM. by mvnisha. Forum started by mvnisha
2503
2349
Traps - Types and Uses
Last answer on 7/3/2011 1:35:26 AM. by S L Gupta (Civil Engg). Forum started by SHAMS
General
What are various types of valves for water pipe lines?
Valve is suitable means of connections for inserting and controlling the flow of the water.Nominal size of stop valve ..
What is the thickness of PVC pipes and diameter for drainage ?
Thickness of PVC Pipes and various diameters for drainage are .........
