Home -> Forums -> Construction -> Brick Walls, Pillars and Structure -> What Should be the size of pillar for the distance of 14 feet for two floor house?
Sat Nov 20, 2010Total posts : 3
sureshdy
sureshdy
Topic: What Should be the size of pillar for the distance of 14 feet for two floor house?
As per planner he suggest that for each 10 feet a pillar of size 9x9" is required, my requirement is for 14' waht should be the size?
Mon Nov 22, 2010Post  #1
Dear sureshdy
         Please tell weather you are constructing brick pillar or RCC column/ pillar..
Mon Nov 22, 2010Post  #2
sureshdy
sureshdy
Post subject: Dear Guptaji
Thanks for response,
It is a RCC column on one and on other end its stone wall of 1 feet see attachment
Attachments: 14 feet.JPG Mon Nov 22, 2010,&n
Wed Nov 24, 2010Post  #3
Dear sureshdy
              The RCC column should be 12''x 18' with MS tor steel bars 6nos 16mm dia. If it is impossible than use the size 9''x9'' but the MS steel bars should be 6 nos 20 mm dia and cement concrete should be in the ratio of 1:1.5:3 .
9229
pillar size in distacce
2695
4588
Reagarding Coulmn Pillar
Last answer on 9/29/2015 11:01:46 AM. by S L Gupta (Civil Engg). Forum started by Amit Kumar
12462
First floor construction
2949
Number and position of pillars
Last answer on 7/3/2020 10:41:58 PM. by Ananda. Forum started by Ananda
2101
2944
1856
dear sir i have a plot of size 14*50 feet and i have a doubt that how many feet
Last answer on 2/17/2021 12:12:23 AM. by S L Gupta (Civil Engg). Forum started by barath kumar
2206
2409
i want to house plan for 1 floor size 17 feet width and 39 feet lenth
Last answer on 5/29/2017 5:57:46 PM. by Saurav anand. Forum started by rajusapra
3795
3635
Last answer on 11/15/2016 1:51:43 AM. Forum started by K Srinivasan
3237
2604
Renovation of old house
Last answer on 5/24/2013 5:06:03 PM. by chandrakanth. Forum started by chandrakanth
2648
Please suggest house Map for ground floor plot Size 10x22.5 feet
Last answer on 8/4/2016 5:21:11 PM. Forum started by Gopal Upadhyay
2352
Check the load
Last answer on 11/17/2013 12:35:51 AM. by Dilip. Forum started by Dilip
3925
Distance between pillars
Last answer on 1/16/2014 3:37:45 PM. by Ahmed. Forum started by Badohi Singh
4389
5811
3793
9885
2670
4628
4143
2865
5008
3657
1865
2801
2610
2373
2462
2638
1807
3608
6254
Brick Pillar
What is acre
Right size cupola
Tips for Oil Bound Distemper
