Sir, I am to build a basement leaving 2 meters each from both of side buildings.
Wed Sep 12, 2012Total posts : 1
Satish bajaj
Satish bajaj
Topic: Sir, I am to build a basement leaving 2 meters each from both of side buildings.
Sir, I am to build a basement leaving 2 meters each from both of side buildings.Rest of the upper floors (stilt 4) will be from wall to wall of side buildings.The size will be 17ft W X 45ft L X 9ft H.(708SqFtCovered Area)I will be highly thankful if you tell me the approximate expenses.My sincere regardsDr Satish Bajaj
Sat Sep 15, 2012Post  #1
piyush
piyush
the approximate basement construction will cost Rs. 1300 per sq. ft and all other floors will cost Rs. 875 per sq. ft.
thanks
pldesignhome 1969
engineer, architect, vastu and interior consultant
pldesignhome 1969@gmail.com
09510472422
Sir I have a plot size 24x65 west facing and a 6 ft gali on left (north side)Ple
Last answer on 7/30/2020 8:16:06 AM. Forum started by S P Srivastava
1651
2845
Construction of new office bilding
Last answer on 2/22/2022 6:39:38 AM. by Anupam Anurag. Forum started by sushil singh
3501
2069
beam and column
2862
2539
by using which software we can see side elevation of building
Last answer on 1/5/2022 12:40:47 AM. by S L Gupta (Civil Engg). Forum started by chethan
3608
18435
1070
building 8" wall onthe slab will effecet the on the outer side
Last answer on 7/4/2020 2:02:31 AM. Forum started by Badhavath Rajeshwar
Help required for construction of basement+ stilt+ 3 floors on 205 sqyd plot in huda gurgaon sector
Last answer on 3/16/2017 10:24:00 PM. Forum started by Mukesh
3178
Estimation software
Last answer on 10/10/2021 12:12:30 PM. by Lola Cooper. Forum started by chethan
1913
building material
Last answer on 3/23/2015 10:00:27 PM. by JAI PRAKASH. Forum started by shaheryar
2557
Bye Law
2585
what is the wall thickness for a 9000 sqft building
Last answer on 4/3/2021 12:46:58 AM. by S L Gupta (Civil Engg). Forum started by shankar
1941
Planning for new house construction
Last answer on 9/16/2015 4:01:37 PM. by Fahim. Forum started by Fahim
2957
Need suggestions
823
Sir i have a plot size 24x65 west facing and a 6 feet gali going on its left (so
Last answer on 7/30/2020 8:25:33 AM. Forum started by S P Srivastava
3992
Orientation
Orientation of Building
Basement Design Ideas
Vastu Guidelines for Basement
Cupola Proportions
Tips for cupola proportions
Basement Ceiling
Basement Flooring
Basement Interior Design
