Sun Oct 08, 2017Total posts : 3
gautam kumar
gautam kumar
Topic: Sir,What is the construction cost of building..per sq.ft ...including( slab,wall
Sir,What is the construction cost of building..per sq.ft ...including( slab,walls, column, beam with material and labour) ???Regardsgautam
Mon Oct 09, 2017Post  #1
HOME
HOME
Post subject: HOME PLANNERS
generally it is 1100 rs sqft.
but it may be depend on what product u are using
Tue Oct 10, 2017Post  #2
        Cost of construction is related to plan of the house and specification used during construction. However in general case it may be from 1000-00 to 1500-00 per sqft.
Sun Oct 15, 2017Post  #3
gautam kumar
gautam kumar
Post subject: construction cost
thank you very much @ gupta sir and Home planners
191901
2666
sir i want to know that what would be the cost total consturction of 2200 sq.ft
Last answer on 2/15/2022 11:12:49 PM. by JAI PRAKASH. Forum started by shruti Adarsh
2176
23866
2869
FOR 250 SQ FT R-B-C SALB RATE
3196
labour cost
2708
type of brick
3925
2564
Labour Cost
Last answer on 8/5/2014 8:13:30 PM. by JAI PRAKASH. Forum started by ferous
1777
Last answer on 8/8/2016 2:46:05 PM. by S L Gupta (Civil Engg). Forum started by arvindkori
16809
Construction Cost per square ft in Gurgaon
Last answer on 2/22/2013 11:53:26 AM. by S L Gupta (Civil Engg). Forum started by Pawan Rao
3542
Contruction Tool
4735
CONSTRUCTION COST OF 3 STOREY BLDG
Last answer on 7/4/2020 2:47:14 AM. by kavi77. Forum started by shakirk78
1829
The prevailing labor wages for construction of RCC building in Vijayawada is 150
Last answer on 1/16/2015 2:10:29 AM. by JAI PRAKASH. Forum started by Vijay
2883
17
18
What is acre
Earthquake
