Size of Column
Size of Column
Wed Feb 15, 2017
Sourabh
Topic: Size of Column
My house 1500 sq ft construction for G+1 is on going. Contractor has build 16 column of 9x9 with 6 bars to 16 mm. Distance between of between 13 to 16 feet. Almost all walls are build 9 inches. Kindly guide if structure is on safer side.
Thu Feb 16, 2017
Dear Sourabh,
The size of column and MS Steel bars are calculated by structural engineer on the basis of plan of building and load to be bear by the column. However it seems to be correct.
Fri Feb 17, 2017
Sourabh
Respected Sir,
I worried because someone told me the 9x9 inches pillars are not safe for G+1 construction.
My contractor made these with his own calculations.Although i have made 70 % of walls 9 inches, but i am still worried on column size.
2994
Last answer on 6/22/2017 11:07:36 PM. by
Anshu
1951
cost of construction for large span of 60'
Last answer on 10/30/2014 12:27:22 PM. by
amit jain
2770
Last answer on 12/31/2020 2:31:54 AM. by
aqeel
65224
Last answer on 7/3/2020 11:37:34 PM. by
syed
Jitendra Sindhi
Last answer on 1/30/2016 2:12:53 AM. Forum started by
rehan
2229
Last answer on 7/4/2020 12:04:58 AM. by
ringwang
3778
Last answer on 12/2/2014 12:34:34 PM. by
hemant
15738
Last answer on 12/8/2014 6:14:14 PM. by
Deep Shrestha
Deep Shrestha
8944
Last answer on 2/15/2015 10:53:28 PM. by
Raymond
6371
Column placement for house
Last answer on 9/13/2017 11:49:12 PM. by
sanjay singh
Parmeswar Giri
5196
ringwang
R.Roy
3497
Last answer on 5/19/2015 9:12:55 PM. by
Wiki
8951
Last answer on 9/11/2020 2:17:26 AM. by
hemant
hemant
4638
Last answer on 11/10/2014 2:26:39 PM. by
hemant
3330
Column footing size
Last answer on 7/4/2020 2:00:01 AM. by
Pooja
1728
I WANT TO KNOW THE DRG OF STEEL IN SLAB AND SIZE OF COLUMNS AND LOCATION FOR
Last answer on 1/16/2015 1:38:26 AM. by
awasthi
Column sizes for Individual House with G+2 design
Last answer on 7/12/2016 1:46:04 PM. Forum started by
Venkat
1955
Dear Sir,Can you please tell me the size of the column and footing for individua
Last answer on 11/25/2020 5:27:11 AM. by
Venkat
Venkat
1606
Residential Structural needs
Last answer on 10/5/2016 12:15:38 PM. by
Padmanabhan
5754
Rakeeb Rathor
3772
Pandu
9871
nasad
2659
Sreedhar
4611
ani
4129
Anamika
2843
lio
5196
ringwang
R.Roy
4948
MANISH
3636
Arvind Bhaskar
4047
premkumarlen
1843
carmenjames
r.n.misra
2780
Sharath Kurva
Sharath Kurva
2596
gk
Adriano Peres
vamsi
2445
nuksung
2625
dayal
1796
TUNDE
3591
ragha
6228
suba
Right size cupola
What is binding wire
