Size of the Roof Level Beam in RCC framed structure
Wed Jan 28, 2015
Arvind Bhaskar
Topic: Size of the Roof Level Beam in RCC framed structure
I am using RCC framed structure for construting a house using concrete hollow blocks for external walls (8"x8"x16") and solid concrete blocks (4"x8"x12") for partition walls.
I am using a grid of columns. The size of the column is 1'x'1 and the maximum distance between columns is 15'. There will be a lintel band at the height of 7'.
The outer walls are 8" thick and the partition walls are 4" thick.
What should be the safe size of the beam considering that I may go in for a second storey in future and considering that lintel beam is kept out of calculation ?
Changed Improved Design-Sleeping-Living-Serving-Plan for uploading.pdf on Wed Jan 28, 2015,&n
Thu Jan 29, 2015
Post subject: Size of the Roof Level Beam in RCC framed struct...
Dear Arvind, Hello..! Kindly plan first floor according to your requirements,and get it structurally designed with the help of Structural Engineer to get
correct sizes
of beams and columns...Regards
Fri Jan 30, 2015
Dear Arvind
As said by Sh Navneet Jharia the correct method is to have proper structure design according to loading. If you want tentative size of beam is 9''x 18''.18'' means 13''+5'' the thickness of slab.
12253
Last answer on 1/18/2013 3:22:15 PM. by
gnyoganarasimhan
selva
3838
Roof Beam
R.Roy
3657
Arvind Bhaskar
ringwang
R.Roy
4431
Last answer on 1/7/2017 7:22:09 PM. by
roshan
roshan
2213
Last answer on 9/14/2021 5:43:01 AM. by
neha
2054
Last answer on 2/15/2017 1:14:19 PM. by
Rajkumar
3273
Roof Concrete Strength
Last answer on 10/12/2014 8:43:10 PM. by
Jahankumar
14602
Last answer on 7/3/2020 10:42:37 PM. by
mpkumar
mpkumar
2526
Last answer on 5/16/2021 2:27:15 PM. by
bhaskar
1748
Last answer on 4/25/2016 3:26:07 PM. by
VIKAS KUMAR
19156
Last answer on 7/3/2020 10:47:35 PM. by
Techman
9197
Vinod
1893
column STRUCTURE
Last answer on 11/9/2015 3:11:28 PM. by
DURJOU KUMAR MONDAL
4040
Last answer on 2/17/2017 11:54:51 AM. by
pramod
2091
Roof TMT needs
Last answer on 12/29/2015 12:27:55 PM. by
Rohit Sharma
4012
labor rate for RCC work
Last answer on 7/28/2020 1:27:06 AM. by
ringwang
ringwang
3002
House Estimation Breakdown
Last answer on 7/3/2020 10:42:10 PM. by
Ayub Khan
Ayub Khan
2299
RCC Framed Structure: Sequence of constructioin
Last answer on 12/27/2014 3:22:06 PM. by
Arvind Bhaskar
5812
Rakeeb Rathor
3793
Pandu
9885
nasad
2670
Sreedhar
4628
ani
4143
Anamika
2866
lio
ringwang
R.Roy
5008
MANISH
3657
Arvind Bhaskar
premkumarlen
1865
carmenjames
r.n.misra
2801
Sharath Kurva
Sharath Kurva
2610
gk
2374
Adriano Peres
vamsi
2463
nuksung
2638
dayal
1808
TUNDE
3608
ragha
6254
suba
Right size cupola
