Home -> Forums -> Construction -> Brick Walls, Pillars and Structure -> Slab construction rate
Wed Mar 02, 2016Total posts : 4
lio
lio
Topic: Slab construction rate
Hi Sir
i want to know total cost and material requirement for 900 sqft slab
Sat Mar 05, 2016Post  #1
Dear Lio
         The material for cement concrete 1;2;4 is cement=63 bags, Sand 220 cft and bazri= 440 cft, MS Steel bars= 800 to 900 kg as per design.
The cost approximately Rs one lac.
Sat Mar 05, 2016Post  #2
Cost would be around 150-200 Rs/Sq.ft.
Fri Jun 10, 2016Post  #3
Vignesh
Vignesh
Post subject: Cost estimation for G+1 house for 1200 land with...
Dear All,
I'm planning to construct G+1 House in 1200 Sq ft Land.
Ground Floor - Full Parking.
1st Floor - house for 1000 sq ft.
Simple villa house i.e ground Floor house,Builder quoted 1400 per sq ft.
Could you please tell me cost with Pillar construction for 1000 sq + concrete roof + house in 1st floor for 1000 sq ft?
Total no of Pillar required for 1000 Sq ft build up:
Approx Cost for one pillar for G+1:
Cost for cement concrete roof per sq Ft:
Cost for house in 1st Floor per sq ft:
Cost for Parking Area (Just Normal Tiles) per sq ft:
Please help me to estimate the cost for G + 1 (Ground Floor parking + 1st Floor House )
Thanks in Advance.
Vignesh
Sat Jun 11, 2016Post  #4
For building, in my view take structure design. The size and numbers of columns,  MS Steel bars are calculated with the structural drawing according to loading condition, safe bearing capacity of soil and effect of earth quack etc.  and design can save construction cost as without design one use more quantity in fear. . See some links for construction
Delete
4012
labor rate for RCC work
2513
1811
Last answer on 1/27/2016 12:04:33 PM. by S L Gupta (Civil Engg). Forum started by A Ghosh
2525
7836
Rcc staircase rates
Last answer on 3/18/2016 4:13:47 PM. by S L Gupta (Civil Engg). Forum started by Shabbir shaikh
4808
2300
2036
What is the construction rate of commercial project in Pune right now.
Last answer on 1/25/2017 12:49:44 PM. by S L Gupta (Civil Engg). Forum started by Ritesh Bodake
2798
2041
estimation
Last answer on 4/30/2013 12:39:09 PM. by S L Gupta (Civil Engg). Forum started by dan
2523
Industrial RCC
Last answer on 5/28/2013 10:17:13 AM. by S L Gupta (Civil Engg). Forum started by shikha Chetal
4109
2408
MY CONTRACTOR IS CHARGING THE SAME RATE OF CONSTRUCTION FOR GROUND AS WELL AS FI
Last answer on 8/22/2013 12:12:50 PM. by Ahmed. Forum started by K S SHYAM SUNDER
3017
Rate of construction of 1st floor of private house 1000sft. in kolkata
Last answer on 2/2/2016 6:19:47 PM. by S L Gupta (Civil Engg). Forum started by A Ghosh
2372
Item rate Constructions better than square feet rate
Last answer on 7/28/2015 12:43:34 PM. by Purvi Panchal. Forum started by BUILDMARK CONSTRUCTIONS
2363
2559
2977
5812
3793
9885
2670
4628
4143
5008
3657
1865
2801
2610
2374
2464
2638
1808
3608
6254
