Slab cost
Thu Apr 04, 2013Total posts : 3
nilesh amolik
nilesh amolik
Topic: Slab cost
I have to build a 1st floor which would be an area of 1350 sq/feet. Need to know how much would it cost in total and only for the slab structure. Also, any idea about the prevalent labor charges only for the slab[only for the centering portion of it].
I hope Gupta sir would be able to look into it at the earliest
Fri Apr 05, 2013Post  #1
Dear Amolik
            The cost of construction of building is related to plan of the building, specification used in the building and lobcation of the area where building is to be constructed. Similarly labor rates also differ. However The labor rate of laying RCC slab including higher charges of centering and shuttering is Rs100-00 cft i.e.length of slab x width of slab x thickness of slab= cft OR Rs 33-00 per sft  i.e.length of slab x width of slab.
Fri Apr 05, 2013Post  #2
nilesh amolik
nilesh amolik
Hello Sir, Thanks for your prompt reply...
Its going to be a 1350 sqft rectangular area with 5 inch slab as instructed by structural designer. But have issues getting to know the cost as different contractors quoting different price. The ground floor is already constructed so plinth and footing is excluded. Construction is to be done in Pune.
Sat Apr 06, 2013Post  #3
Dear Amolik
               If you want detail estimate than contact at support@gharexpert.com where you will find cost and detail quantities.See the link below
Slab cost
Last answer on 2/23/2022 5:00:16 PM. by S L Gupta (Civil Engg). Forum started by Mrityunjay sharma
4074
4818
2874
beam sizes
Last answer on 11/29/2014 3:55:42 PM. by S L Gupta (Civil Engg). Forum started by rupesh
2873
FOR 250 SQ FT R-B-C SALB RATE
2511
What will be coast of slab 5" for area of of 450Sq feet. I want material cost l
Last answer on 10/12/2014 9:25:00 PM. by SANJAY DUSANE. Forum started by milind
4848
1751
cost estimation
Last answer on 11/6/2015 12:42:08 AM. by JAI PRAKASH. Forum started by Muhammad.Muqtar Hussain
2985
2571
11874
cost of rbc and rcc slab
191945
9912
2876
Steel calculation
3898
Cost Estimation of Roof Slab with Beam Structure
Last answer on 4/24/2014 3:21:16 PM. by serin. Forum started by Subhajit Kundu
Cost of RCC Terrace slab and Colomns
Last answer on 6/10/2014 2:29:45 PM. Forum started by a.monteiro
2659
Cost of construction of roof slab.
Last answer on 9/13/2013 11:42:05 AM. by feroz khan patthan. Forum started by suhas
34
Online black magic specialist
Last answer on 1/4/2025 9:31:30 PM. Forum started by ajit
36
Ruhani ilm || 91-8769373431 (())(())( black magic specialist mumbai
Last answer on 1/3/2025 11:36:20 PM. Forum started by rupeshji
15
Last answer on 1/3/2025 11:36:14 PM. Forum started by rupeshji
Last answer on 1/3/2025 11:36:07 PM. Forum started by rupeshji
Last answer on 1/3/2025 11:35:59 PM. Forum started by rupeshji
Last answer on 1/3/2025 11:35:54 PM. Forum started by rupeshji
Last answer on 1/3/2025 11:35:48 PM. Forum started by rupeshji
Last answer on 1/3/2025 11:35:41 PM. Forum started by rupeshji
Last answer on 1/3/2025 11:35:35 PM. Forum started by rupeshji
Last answer on 1/3/2025 11:35:29 PM. Forum started by rupeshji
Last answer on 1/3/2025 11:35:23 PM. Forum started by rupeshji
Last answer on 1/3/2025 11:35:17 PM. Forum started by rupeshji
Last answer on 1/3/2025 11:35:11 PM. Forum started by rupeshji
Last answer on 1/3/2025 11:35:05 PM. Forum started by rupeshji
Last answer on 1/3/2025 11:34:53 PM. Forum started by rupeshji
Last answer on 1/3/2025 11:34:47 PM. Forum started by rupeshji
Last answer on 1/3/2025 11:34:41 PM. Forum started by rupeshji
Last answer on 1/3/2025 11:34:33 PM. Forum started by rupeshji
strong=sakti 91- 8769373431BlAcK mAgIc SpEcIaLiSt ITALY
Last answer on 1/3/2025 11:34:00 PM. Forum started by rupeshji
Last answer on 1/3/2025 11:33:54 PM. Forum started by rupeshji
Reasons of dampness
Centering
Garden
Garden Path Ideas
Advantages
