Slope on a RCC flat roof
Sat Mar 28, 2015Total posts : 6
Arvind Bhaskar
Arvind Bhaskar
Topic: Slope on a RCC flat roof
I have flat RCC roof to which I want to give a slope. The traditional method in Punjab is to use Mud Phuska and overlay it with tiles to achieve the required slope.
Is there an alternative method, if I do not want to use Mud Phuska over my roof.
Sat Mar 28, 2015Post  #1
What is MUD Pushka. please explain in detail.
Sat Mar 28, 2015Post  #2
The other option is to have miner slope in the RCC Slab.
Sat Mar 28, 2015Post  #3
Arvind Bhaskar
Arvind Bhaskar
Post subject: Mud Phuska is mix of slay soil and wheat straw.
The practice here in Punjab is  to put bitumen on RCC flat slab (No slope is given in laying of slab). Then they cover it with Soil mixed with wheat straw (which is called Mud Phuska) to get the slope and then they cover it with tiles.
I understand that putting soil mixed with wheat straw may not be a good practice. I want to give slope by following some other method. The RCC slab has already been laid and it is flat .
Mon Mar 30, 2015Post  #4
k. kaushik
k. kaushik
Post subject: can use light weight "khangar particals"
can use light weight "khangar particals" to maintain a slope on terrace, mason can leigh the same as per your required slope finaly cover the same with cement Mortar as top layer.
Tue Mar 31, 2015Post  #5
Mr. Kaushik, Could you please explain, what is "khangar particals"
Wed Aug 08, 2018Post  #6
Amit
Amit
Slope can be done using cement-concrete screed itself however
The purpose of mud + straw is to provide heat insulation in summers. Problem is if there is crack in top cement layer mud will absorb water and this water will remain there for months. Bitumen is for waterproofing but it is a poor material as the cold winters cause cracks and shrikages.
Other better modern alternatives are
(1)  Use chemical sealants for water proofing instead of bitumen and heat reflective white tiles on the top.
Use Laticrete / Foscrock/ Pidilite newcoat 3 layers on clean roof slab or similar water proofing chemical and put a layer of white ceramic tiles or heat reflecting white tiles at top this will give you advantage of 3 to 5 degree Celsius in the room.  As you know white colour reflects sunlight best it is a good choice in India. Search for heat reflective tile on internet and check of there is any supplier in your area else normal white ceramic will do. Slope can be done while putting mortar for tile laying.
Make sure that you leave small drain holes in parapet to drain out water seeping under tile layer from the edge.
Terracotta tiles can also be used for water proofing above RCC in similar manner.
(2) Traditional Methods:
In MP instead of mud  broken brick / terracotta tile with mortar to give slope and put cement slurry. This is also called Kharanja. It is better then mud and straw however heavy.
(3) If you want thicker insulation
water proof with chemical sealants as in (1) and then use inverted small matki / kulhad layer and lay cement mortar on top. The mortar will fill voids between adjuscent matkis. This will give a light weight insulation layer.
If you have big budget use Chemical sealants + matki / kulhad + white heat reflective tiles.
In my opinion method 1 is best however follow instructions on label of waterproofing sealant rather then going by what contractor or mason says.
2260
advise
Last answer on 8/16/2013 1:07:43 PM. by S L Gupta (Civil Engg). Forum started by faroque
42599
Labour Cost for Roof RCC work
3013
4349
rate comparison
3142
sloping roof
2377
9893
3803
6381
kota Stone Roofing
3754
1702
2054
4648
3980
Roof leakage
4953
1875
6370
Alternatives to RCC roof.HI, I am looking for alternatives to RCC slab roof. Th
Last answer on 9/8/2014 6:10:30 PM. by D.P.S. Forum started by D.P.S
15
17
Decorate
Decorate your Veranda
Veranda or Gallery is an additional space for relaxation and entertainment. It is an opened gallery which is usually o..
Cooper
