Home -> Forums -> Construction -> Bricks -> Solid cement block Vs Bricks
Sun Jun 10, 2012Total posts : 2
jag
jag
Topic: Solid cement block Vs Bricks
I am preparing to construct my house. My contractor is recommending Solid cement blocks for wall construction because of space increase and cost saving . What are the advantages and disadvantages of solid cement block construction over bricks.
Sun Jun 10, 2012Post  #1
Ar. Manoj Ralen
Ar. Manoj Ralen
Hi Jag,
Cement blocks definitely save on space as the width of the cement block is lesser compared to the 9 inch walls so a lot of builders are switching to cement blocks. These blocks are also light weight compared to brick masonry so the dead load is less on the structure. On a high rise building, this reduces the load on the structure. As the blocks are bigger it takes less time to get the wall through these blocks. These blocks are slightly expensive so the upfront cost is a little more and also the blocks usually used in these structures are not 100% solid but have hollow space in between.
Fri Jun 15, 2012Post  #2
jag2
jag2
Post subject: Ebvironment effect
Hi Manoj,
Thank you for your explation,
I have two questions
1. Brick walled houses are more cooler than cement solid block built house?
2. Is there any chance of cracks developing in the walls during course of time
7513
Brick Advice Urgent
3145
Last answer on 8/16/2013 1:12:41 PM. by S L Gupta (Civil Engg). Forum started by K S SHYAM SUNDER
3842
3433
2414
COSTING AND STRENGTH OF WALL
3928
4179
GLASS BLOCKS / BRICKS
3591
2862
2053
construction of house.
Last answer on 7/17/2013 3:42:04 PM. by S L Gupta (Civil Engg). Forum started by Irene
2836
Compound Wall Construction
13651
2466
2025
2595
Last answer on 9/7/2012 4:18:47 PM. by S L Gupta (Civil Engg). Forum started by narsi vekeriya
2405
2336
Last answer on 9/19/2012 1:30:40 PM. by r s rawat. Forum started by mujahedsabb
3494
7513
Brick Advice Urgent
2879
Bricks
2794
brick calculation
2565
Cost of Brickwork
4894
2821
2350
3172
bricks
5658
3238
5135
Use of Solid Concrete Bricks
1624
1341
1846
1479
1797
2966
fly ash bricks
2230
1723
Brick Arches
Specification of Brick
