| Our Web Site is Changing We are updating our website for it looks pleasant, loads faster and be easier to navigate. Also you will find a host o.. |
What is cement concrete and which are various ratios according to the site requirement? The cement concrete is a mixture of cement fine aggregate, coarse aggregate and water.
What precautions should be taken while mixing/laying cement concrete mix to the required site? For general work the different materials required for cement concrete mix is measured loose through measuring box by v.. |
| Preliminary Works during Ground Work Entire area should be cleared of all roots, bushes, vegetation etc. for a smooth construction works. |
| Mild Steel Bars in Cement Concrete Mild steel bars in reinforced concrete are one of the exceptional building materials. Reinforced concrete requires ver.. |
