Specification of ‘Plastering’
Wed Nov 06, 2013Total posts : 1
Subash Chander
Subash Chander
Topic: Specification of ‘Plastering’
Dear Sir, I need more information of reinforcement detailing ,cutting bending and fixing of steel.
The comment above talks about the article   "Specification of ‘Plastering’"
Thu Nov 07, 2013Post  #1
Dear subash
      For laying RCC see the link below
http://www.gharexpert.com/articles/Cement-Concrete-1730/Mild-Steel-Bars-in-Cement-Concrete_0.aspx
Last answer on 4/27/2010 9:56:03 PM. by raghuns1974. Forum started by Mohit
2925
4629
time for paint and wall putty
2781
Plaster work
2438
Gypsum Plaster Vs S/C Plaster
2096
specifications of building materials used in construction industry
Last answer on 9/6/2015 12:27:20 PM. by sanjay agarwal. Forum started by Star Koziba Leladi
2512
1627
Good morning ... can u please let me know the cost,specifications and estimation
Last answer on 10/17/2016 12:12:48 PM. by S L Gupta (Civil Engg). Forum started by syed ameeruddin
3259
2662
sir want the detail specification of acp cladding , such as thicknesss of sheet,
Last answer on 1/17/2013 12:27:08 PM. Forum started by somashekhar
2417
can u give me the specifications of material shown in this picture and appox. ar
Last answer on 7/3/2019 12:31:26 AM. by Ajit Tareeka. Forum started by romaadhikari
2898
2694
cement plastering
35211
2205
7006
1418
where are use in 20mm plaster
Last answer on 10/22/2016 11:07:01 AM. by S L Gupta (Civil Engg). Forum started by Babasaheb Gite
8880
18
Checklist for Cement Plaster
Gypsum
How to clean plaster ceiling?
Plastering
Plastering
