Home -> Forums -> Construction -> Fine Aggregate -> Specification of Fine Aggregate/Coarse Sand
Wed May 07, 2014Total posts : 2
Yousuf khan
Yousuf khan
Topic: Specification of Fine Aggregate/Coarse Sand
pls advise RCC column and Beam thickness for distance 17 foot yousuf khan
The comment above talks about the article   "Specification of Fine Aggregate/Coarse Sand"
Thu May 08, 2014Post  #1
Dear Khan
         Your query is not clear, write in detail so that answer can be given. The half way query and answer does not serve any purpose.
Sat May 17, 2014Post  #2
gaurav
gaurav
dear Khan
as per my view u can built column of minimum 12 x 15 or 12 x 18 as area is little more & beam should be of 9 x 12 . aggregate & course sand & cement should be in ratio of 5:3:1
Fine Aggregate-Construction Questions (21)
2012
coarse aggregate
3495
2245
about construction
1608
Specification of Coarse Aggregate
Last answer on 1/23/2013 1:02:12 PM. by S L Gupta (Civil Engg). Forum started by S P Singh
16073
robo sand vs natural sand
3867
2349
Last answer on 7/11/2010 10:15:36 PM. by Anil Kumar Mishra. Forum started by satish singh
1851
Last answer on 7/11/2011 12:00:45 PM. by S L Gupta (Civil Engg). Forum started by KALPANA
2328
Roof flooring
2658
1556
Last answer on 6/7/2017 12:20:58 PM. by S L Gupta (Civil Engg). Forum started by Sandeep Vidwans
1304
1767
1460
831
How to use loans without risk of fines?
Last answer on 4/3/2021 12:44:54 AM. by aglar. Forum started by terimad
1670
3715
4241
mix design of rcc slab
Last answer on 7/31/2012 11:18:03 AM. by S L Gupta (Civil Engg). Forum started by ranvir kumar singh
2747
3616
Can we use crushed Sand for house construction
Last answer on 4/8/2014 12:28:09 PM. by S L Gupta (Civil Engg). Forum started by Purvi Panchal
3495
Density of Coarse Aggregate
What is aggregate
There are mainly two types of aggregate:Fine aggregate and coarse aggregate. Let us know more about aggeregate in foll..
Aggregates of concrete and their density
In cement concrete aggregates occupy 75-80 percent volume of concrete, so you can say Aggregate is a major resource fo..
Coarse Aggregate consists of crushed, uncrushed or broken stones. Check the grading of sand for proper sizes.
