Specification of Water
Mon Mar 22, 2010Total posts : 3
AYYAZ SHAIKH
AYYAZ SHAIKH
Topic: Specification of Water
I plan to dig a borewell for using water for constructing my house. The land is in Chikhali(behind tata motors pimpri) please advice
The comment above talks about the article   "Specification of Water "
Tue Mar 23, 2010Post  #1
Post subject: Bore well location
You can dig the bore well in the Northeast and use it for constructing the house. Also do not place heavy material like bags of cement/bricks or other material in the NE while constuction of the house.
Wed Mar 24, 2010Post  #2
Post subject: Reply-Specification of water
Dear Ayyaz,
Water is most important elements in construction work. The water used for mixing and curing should be clean and free from injurious quantities of alkalis, acid, oils, salt, sugar, organic materials, vegetable growth and other substances that may be deleterious to bricks, stone, concrete or steel. Potable water is generally considered satisfactory for mixing. The ph value of water should be not less than 6.
                           In general thinking that the water fit for human consumption is generally acceptable for mixing mortar or concrete and curing work for construction work. However, the water must be tested before using in construction work. When you are making huge expenditure on construction work, a negligible amount spent on water testing should not be saved. Tested water or treated water should be used as this will increase the strength of cement concrete and enhance the life of building. For more detail about water for construction, take help from the article water for construction link given below    http://www.gharexpert.com/articles/Water-1837/Water-Construction_0.aspx
S.L.Gupta
Wed Jun 16, 2010Post  #3
SHEIK
SHEIK
Post subject: Specification of Water
is there any practical possibility of reducing the salt content of bore water.
underground water tank
3163
APP membrane
1626
Good morning ... can u please let me know the cost,specifications and estimation
Last answer on 10/17/2016 12:12:48 PM. by S L Gupta (Civil Engg). Forum started by syed ameeruddin
2096
specifications of building materials used in construction industry
Last answer on 9/6/2015 12:27:20 PM. by sanjay agarwal. Forum started by Star Koziba Leladi
2511
3258
2416
can u give me the specifications of material shown in this picture and appox. ar
Last answer on 7/3/2019 12:31:26 AM. by Ajit Tareeka. Forum started by romaadhikari
2897
2660
sir want the detail specification of acp cladding , such as thicknesss of sheet,
Last answer on 1/17/2013 12:27:08 PM. Forum started by somashekhar
3370
2234
2180
pile work
5055
6414
2541
water softner
3559
Cost of construction
Last answer on 3/19/2013 11:44:19 AM. by S L Gupta (Civil Engg). Forum started by saurabh ramya
2035
Dear Gupta sir,Can you please suggest the detailed specification for a good foun
Last answer on 5/8/2013 12:14:58 PM. Forum started by nithun
2230
sewage pipes
Clean and clear water is quite suitable for construction work.
60
60 Tips to Save Water
Vastu for Water Tank
Water for Construction
What is the specification of Garage door?
Specification and Purchasing Guidelines of Marble Chips
Marble chips must be crushed mechanically and be free from marble dust and foreign matter.
What is the specification of glazed tile ?
The tiles shall be of approved make and shall generally confirmed to ISI 777 .
Sanitary
