Specification for house construction
Tue Jan 21, 2014
kumar
Topic: Specification for house construction
Hi Experts,
I am going to construct a house of 2000 sq.ft in Coimbatore,Tamil nadu.
One of a civil engineer I have discussed sent me the attached specifications.
He is charging 1450 per sq.ft. Please take a look at the doc and advise me if the specifications is right for the above cost.
Thanks,
Kumar
BUILDING QUOTATION G. FLOOR &F.FLOOR.doc on Tue Jan 21, 2014,&n
Wed Jan 22, 2014
Please upload the floor plan also. it will be easy to reply
Fri Jan 24, 2014
Dear Kumar Gharexpert.com website have a service for detail estimate based on drawings and prevailing market rates. If you have detail estimate with your engineer specification than there is clear picture with you about quantity of materiel rates and cost for which you have better dealing and management. Link given below http://www.gharexpert.com/Estimator/detailed_cost_estimate.aspx http://www.gharexpert.com/articles/Start-Construction-1406/Through-rate-contractor;-guidelines-better-rel_0.aspx
Sun Jan 26, 2014
kumar
Post subject: Floor plan
Hi Sir,
Thank you for your reply. I have gone through the links that you sent. It is very useful.
Hi Purvi,
Thanks for taking a look at it. I have attached a Floor Plan now. Please give it a look.
Thank you,
Kumar
Jayamani Vellamadai Final-Model.G.F.pdf Sun Jan 26, 2014,
Jayamani Vellamadai Final-Model.F.F.pdf Sun Jan 26, 2014,&n
Sun Jan 26, 2014
Post #4
kumar
Post subject: compound wall
Also please let me know how much will cost for compound wall construction for 3100 sq.ft
3257
Last answer on 7/30/2014 10:51:01 AM. by
Dhananjay
2095
specifications of building materials used in construction industry
Last answer on 9/6/2015 12:27:20 PM. by
sanjay agarwal
Star Koziba Leladi
2511
Last answer on 2/11/2022 10:20:15 PM. by
goxah55535
YUVARAJ
3277
Re. house construction specifications from the contractor
Last answer on 10/12/2021 12:34:05 AM. by
vignesh_mp
3559
Cost of construction
Last answer on 3/19/2013 11:44:19 AM. by
saurabh ramya
2123
Cost of Construction
Last answer on 8/19/2013 11:11:40 AM. by
Naveed Mohamed
10900
Last answer on 2/8/2021 2:14:37 AM. by
John
karthik
1652
SPECIFICATION INPUTS FOR MY HOUSE PLAN
Last answer on 6/27/2016 2:06:28 PM. by
Construction Specifications
Last answer on 2/14/2013 5:06:46 PM. by
Vikram
3879
Last answer on 9/22/2021 6:50:36 AM. by
Last answer on 12/14/2020 9:46:53 PM. by
Mubarak Khan
4073
Last answer on 7/4/2020 2:32:53 AM. by
satish
2572
house construction plans for 20x30 site
Last answer on 7/4/2020 2:28:10 AM. by
Amrit Bhagat
ramu
1809
Last answer on 1/27/2016 12:04:33 PM. by
A Ghosh
2019
Last answer on 7/3/2020 10:54:45 PM. by
zakia sultana
2616
COLUMN nd LOAD BEARING
Shivaraj
Shivaraj
2299
Last answer on 2/22/2022 2:58:13 AM. by
Vishal
1594
Checklists for flooring
Last answer on 4/4/2015 7:09:35 PM. by
MUTHU
1783
Last answer on 3/17/2021 12:53:46 PM. by
MD KAMIL RASHID
Specification of Water
Clean and clear water is quite suitable for construction work.
Specification of Steel
Gray Cement
Do you know the strength of a building depends on the quality of cement? Cement/ Gray cement is one of the most import..
