Home -> Forums -> Construction -> Brick Walls, Pillars and Structure -> Specification of 'Bricks Walls'
Mon Jul 05, 2010Total posts : 12
sourabh garbhe
sourabh garbhe
Topic: Specification of 'Bricks Walls'
if we found the strata at ground level itself then how deep should we dig for foundation?
The comment above talks about the article   "Specification of 'Bricks Walls' "
Tue Jul 06, 2010Post  #1
Dear Sourabh Garbhe
                        Foundation of walls & columns should be excavated at least from 2 to 3 feet deep in the ground to accommodate the steps of foundation and foundation is well protected inside the soil.
Thu Aug 12, 2010Post  #2
R. PANDEY
R. PANDEY
Post subject: Specification of 'Bricks Walls'
The depth of the foundation walls as shown in the sketch is in sufficient. depth of foundation walls should br >2 to 3 feet, depending upon the type of soil,its strength bearing qualities & height of the superstructure to be provided i.e. load to be transmitted.
Fri Aug 13, 2010Post  #3
raj basumatary
raj basumatary
What about use of aac blocks instead of normal bricks? It it heat resistant so would be very good for indian summers. It is very light and therefore transportation cost reduces. It is also very durable. An article about these aac blocks along with its cost in india would be very helpful. Raj
Tue Oct 05, 2010Post  #4
cdhavse
cdhavse
what is the rate of building a single brick wall with both side plastered, this is for partitioning a room. Thanks
Wed Nov 03, 2010Post  #5
Qasim
Qasim
Asalam-mu-Alakum i am a student of quantity survey. can any body tell me how calculate the steel bars. plz plz complete method of steel calculate? thanks for any body those friends can send me answers
Mon Apr 18, 2011Post  #6
jchax
jchax
Can we use cellular lightweight concrete (CLC like Duro Vert CLC) blocks for constructing load bearing walls?
Tue May 03, 2011Post  #7
JALEEL
JALEEL
do you have any idia regarding brick dome and vault,how to count qty ?
Thu Nov 03, 2011Post  #8
kumar
kumar
i want to know construction cost of swimming pool 40 x30 and 30x 18
Tue Jan 31, 2012Post  #9
Basha
Basha
Can we construct a 9" wall on a cantilever slab spanning 20' and projecting 2'6" beyond a load bearing wall of 15". please let me know can we construct or not.
Sat Apr 20, 2013Post  #10
J Sridhar
J Sridhar
Need first class bricks. Are there any manufacturers in Uttarakhand or Delhi please?
Fri Apr 18, 2014Post  #11
ismail
ismail
Yes... fantastic, very useful information, thanks to consult engineers.
Thu Oct 29, 2015Post  #12
rump6767
rump6767
Hi, how can the cement rendering be protested against dampness. thanks
3469
Cost of concrete walls
2897
3080
2875
1814
4054
9195
2991
2865
Bricks
3992
2835
Compound Wall Construction
13650
2275
wall
Last answer on 12/12/2012 12:27:36 PM. by S L Gupta (Civil Engg). Forum started by saif
3118
concrete brick or clay brick
3409
HOW TO CALCULATE BRICK IN A 200 SQF WALL WITH HIGHT IS 10 FEET AND WIDTH IS 9"
Last answer on 8/21/2011 3:35:21 PM. by S L Gupta (Civil Engg). Forum started by sohail
3668
wals
5006
3078
How much time curing is required for bricks wall.
Last answer on 6/17/2016 12:45:17 PM. by S L Gupta (Civil Engg). Forum started by MANISH
5811
3792
9884
2670
4627
4143
2865
5006
3655
1864
2800
2610
2372
2462
2638
1807
3607
6254
Specification of Brick
Brick Arches
Canvas
Canvas Wall Art
Buying tips for Bricks
Buying tips for Brick Blast
