Sat Apr 17, 2010Total posts : 11
shalu sachdeva
shalu sachdeva
Topic: Specifications of marble stone flooring
Enter detail of discussion it is very helpful but i want to know more varieties in marbles. i've heard that more costly is the marble it tends to get crack easily while laying(more wastage). low rates marble are hard &does not crack .is it true? ng this article
The comment above talks about the article   "Specifications of marble stone flooring "
Thu Apr 22, 2010Post  #1
Dear shalu sachdeva
There are over 3000 varieties in marble stone available in the world market. Marble deposits are wide spread in India mainly in the states of Rajasthan, Gujarat, Madhya Pradesh and Andhra Pradesh.
           Rajasthan is the main depository of marble in India accounts for over 90% of total marble production of the country, with reserves spread over the districts of Nagaur, Udaipur, Rajsamand, Banswara, Dungarpur, Jaipur, Sirohi, Bhilwara, Ajmer, Bundi, Alwar, and Pali. Some varieties  are given below:
Makarana Marble, the main sub-varieties are Kumhari, Doongri, Alberta, Chosira, Pahar Kuwan, Bhot, adanga marble, Makarana chalk, Abu white and Makaran White. Rajnagar Marble is the largest marble-producing area, having units located in the nearby town of Kishangarh to process the material produced. Agaria, Dolomitic,quartz is the best variety of this area. Andhi Marble located near the capital city of the state of Jaipur, the varieties are pista (pistachio) marble, One of the famous varieties of this area was known as Indo-Italian, owing to its resemblance with Satvario Marble. Most of the mining of this famous field is now banned by the Supreme Court of India. The other varieties are Peta Pasu, Uadepur green, Umer ( Bundi ) Jaislmer and Narnaul marble etc.
           In Gujarat, Amba Ji Marble and Baroda green etc. In Madhya Pardesh, Kattani Range and Jabalpur range are famous for marble stone.
           It is not hard and fast rule that costly marbles are more breakable. The hardness and breakage are according to the nature of the stone ore, its crystalline texture and its sound, dense and homogenous nature of stone.
Sat Apr 24, 2010Post  #2
M Jindal
M Jindal
Post subject: Quite informative neha
I liked it and found it useful if anyone want to purchase marble.
Mon Apr 26, 2010Post  #3
Siva
Siva
Post subject: Specifications of marble stone flooring
Can any one please advise how to ensure that marbel purchased from local supplier is right quality or brand. Is there any stamping on the marble itself?
Fri Apr 30, 2010Post  #4
priya
priya
Post subject: advice
Dear shiva
You can visit internet to find out the reliable companies that are offering high quality marbles. Bcoz there is no industry standard to judge a quality of marbles but there are some ways to catch the quality of marble.. like
  • If the back of the marble tile appears to be covered in a mesh or net, this marble is more fragile than others.
  • Examine the surface of the marble under a light, holding it at a 45-degree angle. If there are small, dull patches on an otherwise polished surface, the marble may have "fill" in small holes or    fissures in its surface.
  • Ask for the marble's complete name. Thasos AAA is a higher quality of stone than standard Thasos.
  • Consider the marble's hardness factor. If a stone has a high hardness factor it means it is a poor quality tile.
Thu Jul 08, 2010Post  #5
Vassilios Papadakis
Vassilios Papadakis
I have a big quantity of 20 mm polished slabs of a coloured marble, similar to Giallo Siena, with raisin and net on the back. Is it possible to grind them and polish them to 15 mm without breaking them?
Thu Feb 03, 2011Post  #6
praveen
praveen
what precautions take while rcc roof filling
Mon Jul 11, 2011Post  #7
Girish
Girish
Limestone -> Marble -> Granite these are the three grades. Limestone more porus than Marble. Marble porus compared to Granite. few additional factors related to marble usage. 1) a marble slab are available in diff. ranges. the one with few or no lines (the sediments) is treated as the prime quality. 2) application of liquid waterproofing coating below marble help avoid moisture from the slab or screed below getting into marble and decolouration. 3) Top surface coating solutions are available to make sure the quality of polish and marble finish remain excellent for long time. the minute pores in marble do absorb moisture or any other elements which can result in loss of finish , colour 4) Marbles can be used for cladding - use of SS cladding anchors or tile adhesive recommended than use of cement screed. 5) being a natural stone variation is very much there on marbles, so trial laying the tiles before fixing to make sure the variation dont effect the final look is always advised. specially when tiles are cut from diff. slabs
Wed Jul 13, 2011Post  #8
PREM NATH CHIKNA
PREM NATH CHIKNA
Due to poor workmanship my marble floor is not looking good because of poor alignment of slabs. In some places the gap is even more than 4-5 mm.is it possible to rectify the same at this stage.Please suggest most economical way if any.
Sat Aug 04, 2012Post  #9
gouti balraju
gouti balraju
I want to fix basant beton 65 mm thick paver blocks on ramps. what will be the mortar mix and what care should be taken while laying blocks. mortar mix proportion and top layer details.
Wed Mar 20, 2013Post  #10
Sri
Sri
Morwad White Marbles NEW - Good Quality, No Filling or Quarks. Morwad White Marbles from Kishangarg, Jaipur-Rajasthan for sale in CHENNAI. If interested please call me at 8148100546
Wed Jun 03, 2015Post  #11
moeen akhter
moeen akhter
great
3351
2525
Natural Stone Flooring
Last answer on 7/3/2020 9:23:41 PM. by kevinlee. Forum started by Jenne White
3382
1597
How much Marole required
2300
marble flooring is done and pop work is over can i start birla putti before marb
Last answer on 7/3/2020 11:35:07 PM. by JAI PRAKASH. Forum started by ashok
2316
Hi my Name is Riyaj khan i am Marble flooring liver incharge for indian Marble,
Last answer on 7/3/2020 11:34:52 PM. by JAI PRAKASH. Forum started by RIYAJ KHAN
1771
1611
flooring white marble in 700sq ft areaestimate plz9718739994
Last answer on 10/4/2016 9:21:30 PM. Forum started by Kamrul
3148
Last answer on 7/3/2020 9:54:13 PM. by S L Gupta (Civil Engg). Forum started by padmaraju
1669
Cement requirement
923
For laying marble what is better of 'lal rorhi' and stone gatki with mixer. lal
Last answer on 2/3/2019 10:58:08 PM. by Surinder Singh. Forum started by Surinder Singh
3113
Marble Flooring for flat
Last answer on 7/3/2020 11:32:44 PM. by Gunjan Utraja. Forum started by pumping iron
2264
What are the basic requirements of crazy marble stone flooring?
Last answer on 12/31/2020 2:38:45 AM. by sanjay singh. Forum started by Abraha Avi
3603
Tile flooring verses Marble
Last answer on 7/3/2020 9:54:03 PM. by Deven. Forum started by Love thy community
3466
Kindly guide us for which type of flooring like marble, vitrified tiles is suita
Last answer on 4/12/2010 4:08:33 PM. by M Jindal. Forum started by Sanjay jain
404
flooring
Last answer on 12/18/2010 12:30:53 PM. by S L Gupta (Civil Engg). Forum started by ali
2249
which flooring is suitable - marble or marbonite for heavy traffic area ?
Last answer on 2/5/2011 7:06:44 PM. by Nikita. Forum started by vikram khot
Specifications
Specification and Purchasing Guidelines of Marble Chips
Marble chips must be crushed mechanically and be free from marble dust and foreign matter.
Italian
Italian Marble Flooring
MARBLE STONE
Marble shall be hard ,sound , dence, and homogeneous in nature with crystal in texture as far as possible.
What
Crazy marble floor is suitable for Drive way, Courtyard, Verandah etc. When marble flooring is installed in the main b..
Purchasing Guidelines for Marble and Granite Stone
Marble stone should be hard, free from any stain i.e. deep cut or mark on the surface.
Appropriate
Colors
Colors of Kota Stone
Kota Stone is a natural stone found in attractive, beautiful and eye soothing natural shades of greenish blue and brow..
Advantages
What is the recommended thickness of the under and the top layer of terrazzo tile flooring?
The under layer is made up of cement concrete in 1:2:4 Ratio (1-Cement,2 corse sand, 4 stone aggtregate ) and is aroun..
