Home -> Forums -> Construction -> Start Construction -> Sq Ft Calculation for Mastry-Urgent!
Wed Feb 22, 2017Total posts : 4
Neel
Neel
Topic: Sq Ft Calculation for Mastry-Urgent!
Hello Experts,
We constructed a house using a (Mastry) contractor only labour contract basis per Sq Ft 180 for Roof area for cement work only.
Its a double storied house and we have first floor staircase outside and on top of that to avoid rain coming into balcony we have put cement slabs by raising the parapet wall 3 ft , which are poured using cement and steel and then plastered it.
And in elevation we have made some groves and additional projection design attaching to roof.
Now the question when we calculate and pay the Mastry or the contractor do we measure only till the Roof length and width leaving any projection which are ornamental in the front side.
As we covered the top of the staircase do we need to measure that also as a separate roof.
Because while calculating our Contractor is putting all these things into Sq ft and also adding the top of the staircase as additional roof which is around 66 SQ FT and also adding the 6 inches length eventhough its only 5 feet in width he is adding it to the total roof area.
So we are confused as this is going over 40 thousand. When we questioned him he said its considered as roof and in the agreement we have mentioned that Elevation is free which is included in the SQ FT 180 only.
Request you all to clarify. As we don't want to cheat him or get cheated
Neel
Thu Feb 23, 2017Post  #1
Dear Neel,
        When there is agreement than pay him according to agreement.
For projection the area is taken as 50 %.
Thu Feb 23, 2017Post  #2
Neel
Neel
Thanks a lot for your answer sir,
Yes now that is the problem he is saying that project is also considered under roof area.
For example total length of roof is 42 feet and their is a projection of 9 inches
and Width is 32 and their is design of 6 inches projection
He is saying now when you calculate Sq ft L X B  as per him 42.9 is the length  and Width is 32,6
So we got a doubt that whether the projections are added into Roof area or not.
As you mentioned how to take it as 50% little bit of confusion.
Neel
Thu Feb 23, 2017Post  #3
sanjay agarwal
sanjay agarwal
The Length should be 42.75 feet
and width 32.5 feet.
Mon Feb 27, 2017Post  #4
Neel
Neel
Sir
thanks for all the answers
Neel
14312
20 sq ft and 50 sq ft how can i make house with vastu
Last answer on 12/24/2012 3:50:59 PM. by S L Gupta (Civil Engg). Forum started by saravanan
3113
estimation
Last answer on 7/3/2020 10:38:18 PM. by jayaraaj. Forum started by j.maheswari
Estimation for ground + 2 floor
Last answer on 2/27/2015 10:52:31 PM. Forum started by sboloor
2185
Marble required for flooring
Last answer on 1/7/2022 12:44:11 AM. by S L Gupta (Civil Engg). Forum started by K. Basu
5353
main door vastu question
Last answer on 7/4/2020 3:03:42 AM. by geetika. Forum started by sujatha
3130
3830
3083
1965
I have constructed my house thru one of local contrctr at the rate of 1300 per s
Last answer on 12/4/2014 1:21:13 AM. by JAI PRAKASH. Forum started by mani
4618
suggest a house plan for 50 Sq. Yd. (22 Ft. Width, 20 Ft. Depth)
Last answer on 5/17/2016 12:17:53 PM. by Beenu Phogat. Forum started by VISHU DHINGRA
4797
Last answer on 1/13/2014 2:23:28 PM. by S L Gupta (Civil Engg). Forum started by balaji
4331
2163
i want office furniture (desk cabin desk & cbinet storege)colour combination of
Last answer on 2/23/2022 1:50:41 AM. by seema tyagi. Forum started by savani
3196
labour cost
1881
1972
Elctrical wiring
1421
i needs urgently 10*49 sq ft,housh plan, for 2bedroom 1 hall 2 bath
Last answer on 2/23/2017 11:21:28 AM. by S L Gupta (Civil Engg). Forum started by anshul
2005
if any have photos of best house plans with 900 sq.ft plse send it
Last answer on 7/27/2016 2:33:34 PM. by Beenu Phogat. Forum started by ram
3312
2312
What is acre
