Home -> Forums -> Construction -> Start Construction -> Standard weight of iron grill per feet
Sun Aug 24, 2014Total posts : 1
Topic: Standard weight of iron grill per feet
What is standard weight for window local iron grill and bright bark grill per feet.
Mon Aug 25, 2014Post  #1
Ask a craftsman. It may differ as per the diameter of the iron rod or pipe u want to use.
4081
1975
Expert Help - Window & Doors
Last answer on 12/24/2015 4:18:32 AM. by JAI PRAKASH. Forum started by sushantsah
2800
sand wight per cu.feet
Last answer on 11/5/2012 11:47:35 AM. by S L Gupta (Civil Engg). Forum started by aammiitt
4013
what is the weight of MSA 45x45x6 angle per meter?
Last answer on 12/31/2020 2:08:28 AM. by Priti Arora. Forum started by K.SRINIVASAN
3328
Tips for Office Furniture
Last answer on 1/8/2022 3:03:34 AM. by Sandy Parker. Forum started by 3guptaanurag
2721
present cost of constuction per sq feet
Last answer on 11/29/2011 3:40:09 PM. by S L Gupta (Civil Engg). Forum started by ajeett
2614
tiles
2651
I want to know the cost of this flooring per square feet
Last answer on 8/27/2013 12:29:33 PM. by S L Gupta (Civil Engg). Forum started by b.jaganathan
2086
Types of Windows and Door options in uPVC
Last answer on 5/25/2015 12:51:15 PM. by JAI PRAKASH. Forum started by harsha gv
2109
strong glass to replace grills
Last answer on 1/16/2014 4:27:47 PM. by MANJUNATH. Forum started by ahsan
1687
on mat iron pillar nos on eastern side -30 feet s are erected and concrete done.
Last answer on 7/29/2014 12:20:16 PM. by S L Gupta (Civil Engg). Forum started by bhushan.k.g.m.
2117
Last answer on 1/16/2022 11:07:26 PM. Forum started by Aly Atif
3439
I want do construct a home, plot size (20x50)feet.What is the construction cost
Last answer on 3/25/2016 3:05:19 PM. by S L Gupta (Civil Engg). Forum started by Santosh Singh Bhadoria
2056
Last answer on 1/8/2018 11:06:10 PM. by S L Gupta (Civil Engg). Forum started by ravikumar
2770
1352
what is the standard labour outputs for different work in is code
Last answer on 7/4/2020 4:30:08 AM. by S L Gupta (Civil Engg). Forum started by santosh pore
1982
Standard Awnings For Home
Last answer on 7/3/2020 10:26:05 PM. by S L Gupta (Civil Engg). Forum started by Shel Jones
42084
2173
I want to cover my terrace because of leakage problem during rains.If i want to
Last answer on 9/12/2014 9:53:08 PM. by JAI PRAKASH. Forum started by Akshata Rao
2442
3265
3278
4424
3970
2187
2695
4205
5159
2370
2288
1991
2441
2110
3190
2041
12508
2157
2005
2721
Precautions
Basic
Basic home security tips
Home Security Grills and Their Fabrication
Good quality security grilles can ensure safety and protect home from burglars and intruders. Nicely fabricated windo..
What are various designs of grills in windows?
Window Grills are required for the safety of homes. Window glasses should be well covered with grills. Here are variou..
Which are various types of grills for home ?
Aluminum grills have high tensile strength.
Precautions
Precautions during Fabrication and Fixing of Window Grill.
Any small carelessness during fabrication works can deform the shape of steel doors and windows etc. Fabrication shoul..
