Pillar Work
Mon Jun 05, 2017
Shekar Nair
Topic: Steel Rod TMT FE 500 & FE 500D
I am building a 2 storied house. My architect said he will used Steel Rod - FE
500D
for foundation and pillar work.
But I found that the rods are only FE500. (It is embossed on the steel rods).
Is it safe to build an extra storey in future with FE 500 ?
Or should I ask him to change to FE 500D?
Please answer.
Thu Jul 19, 2018
Dear sir,
Thank you.
1528
Last answer on 9/16/2018 11:00:00 PM. by
Muhammad
1199
Hi,TMT grades like Fe 550 and Fe 550D, what makes Fe 550D more ductile. Why is t
Last answer on 2/19/2019 11:14:50 PM. Forum started by
Vineeth V
9360
Last answer on 5/21/2018 11:53:16 PM. by
George Kattapuram
2723
can you pl discuss the disadvantages of using higrade steel such as fe 650 700 f
Last answer on 12/31/2020 2:09:55 AM. by
H S Rathi
Raman
2246
FE
Last answer on 9/12/2010 7:11:08 PM. Forum started by
VIPUL
1293
My contractor keep on insisting FE 500 for our new home. My wife is a civil engi
Last answer on 7/4/2020 3:55:42 AM. by
Rekha R
721
Last answer on 9/19/2020 12:24:32 AM. Forum started by
Rohit Kumar
1163
When we bought TMT bars for house, they said it was anti-rust. We had to stop ou
Last answer on 8/19/2018 11:54:21 PM. by
Vineeth V
3179
Last answer on 3/14/2021 11:13:22 AM. by
venkatesan.pt.
1991
Residential complex
Last answer on 6/30/2021 4:27:52 AM. by
lali
1698
TMT rod to be used for the structure
Last answer on 10/3/2015 11:39:32 AM. by
nhrajesh
1740
Last answer on 7/4/2020 4:27:11 AM. by
Anu Mohan
1945
Last answer on 7/3/2020 11:23:38 PM. by
rajesh
8651
Last answer on 7/23/2012 11:37:26 AM. by
dominate27
3206
steel
Last answer on 7/4/2020 2:34:09 AM. by
Last answer on 7/23/2018 11:36:52 PM. by
AMIT KUMAR VERMA
65238
Last answer on 7/3/2020 11:37:34 PM. by
syed
Jitendra Sindhi
4366
RCC Columns
Last answer on 4/14/2021 6:24:55 PM. by
Ahmed
Ahmed
2889
Pillar distance and steel rod dia
Last answer on 8/1/2014 7:37:46 PM. Forum started by
SAROJINI
32559
Cost of RCC Pillar
Last answer on 2/23/2022 11:59:24 PM. by
Subhajit Kundu
6436
position of pillars
Last answer on 11/18/2021 10:47:57 AM. by
ani
1878
column
Last answer on 3/5/2021 2:07:49 PM. by
karthick
1780
First floor plan suggestions
Last answer on 2/10/2021 12:02:12 AM. by
Naveen
2522
Pillar cost
Last answer on 11/27/2020 8:35:14 AM. by
P Saravanaraj Pandian
4036
Last answer on 11/19/2020 9:31:03 PM. by
shakthi
shakthi
42123
Last answer on 7/4/2020 12:16:25 AM. by
Seetharaman
SARDAR
12461
First floor construction
Last answer on 7/4/2020 12:01:33 AM. by
chidambar
2503
Length of cantilever beam
Last answer on 7/3/2020 11:33:29 PM. by
ABCD
2536
RCC column (pillar)
Last answer on 7/3/2020 11:20:24 PM. by
bibhas naik
9225
pillar size in distacce
Last answer on 5/8/2017 1:45:45 PM. by
Pandu
jaybiswa
9195
Vinod
2823
Last answer on 8/22/2016 11:02:03 AM. by
Praveen
2694
Last answer on 8/16/2016 11:39:31 AM. by
freekundli
MASTHAN
1993
Last answer on 7/23/2016 10:47:39 AM. by
akash
2206
Last answer on 1/31/2016 11:10:30 PM. by
Raja
Last answer on 1/30/2016 2:05:49 AM. Forum started by
rehan
Last answer on 10/14/2015 2:12:26 PM. Forum started by
S Deep
3159
Laping length requirement
Last answer on 9/2/2015 12:21:21 PM. by
bala
Steel Roofing
Specification of Steel
