Steel Size
Steel Size
Wed Aug 20, 2014
ferous
Topic: Steel Size
Hi All,
Would like to know the size of Steel (for Beam) which will be good for a strong building size of 700 (G+2)
Thu Aug 21, 2014
The number of steel bars and diameter of steel bars in beams, column and slab are calculated on the basis of load coming on it. The load is calculated on the basis of length of beam and distance of beam to beam.
1683
Home Construction
Last answer on 7/3/2020 11:12:41 PM. Forum started by
Rajesh
3820
What is the plinth Beam properties for Ground +3 residential building?
Last answer on 10/14/2013 1:14:49 PM. by
ananth
2083
help
Last answer on 1/9/2015 12:09:16 AM. by
Asif
3108
Last answer on 12/31/2020 1:53:26 AM. by
N.S.BISHT
Pujesh Mallick
1762
mohd asif
8651
Last answer on 7/23/2012 11:37:26 AM. by
dominate27
1695
Roof related
Last answer on 3/5/2016 10:32:12 PM. by
Pooja
2216
Last answer on 4/21/2015 11:35:52 AM. by
RCC Roof
Last answer on 7/4/2020 12:19:59 AM. by
ARVIND GOYAL
4331
Last answer on 3/15/2011 6:15:21 PM. by
Mohini Sharma
kanwer sajjad
15583
Last answer on 7/26/2021 2:26:58 AM. by
Last answer on 7/3/2020 11:37:34 PM. by
syed
Jitendra Sindhi
1620
Residential Structural needs
Last answer on 10/5/2016 12:15:38 PM. by
Padmanabhan
1204
Sir i need help for built 2 story house 1. steel for rcc roof?2. how many via /
Last answer on 7/12/2017 12:28:18 AM. by
Waseem Ashraf
4939
COLUMN AND STEEL DESIGN
Last answer on 1/9/2021 12:01:44 AM. by
Kaleemullah
4939
Kaleemullah
3207
steel
Last answer on 7/4/2020 2:34:09 AM. by
Last answer on 2/22/2021 2:25:37 AM. by
Mohiuddin
2328
Last answer on 9/23/2013 11:44:05 AM. by
HYDER ALI
9061
makan map
Last answer on 2/23/2022 7:31:55 PM. by
VINOD KUVERA
2774
Last answer on 2/13/2022 9:36:52 PM. by
Radha Athipathi
17223
Last answer on 11/12/2021 11:49:48 PM. by
Anbusagar
Vijaya Kumar
1993
Last answer on 11/1/2021 12:03:57 AM. by
sachin
2157
design of column
Last answer on 9/28/2021 10:18:53 AM. Forum started by
Last answer on 9/15/2021 1:26:25 AM. by
himanshu
srinivas kamsali
2253
Underground water tank
Last answer on 6/21/2021 2:04:48 PM. by
Sanzana Hosen
2658
Last answer on 6/11/2021 11:03:58 PM. by
ankit
2764
foundation
Last answer on 5/28/2021 2:19:12 AM. by
shashidhar
2033
Full Plan Needed
Last answer on 5/27/2021 1:05:19 AM. by
Riz
3196
labour cost
Last answer on 4/9/2021 5:38:18 AM. by
narendra adkine
3163
APP membrane
Last answer on 4/7/2021 11:05:28 PM. by
upsersv2e
Last answer on 4/3/2021 12:47:27 AM. by
Roogwed adep
1970
ffff
Last answer on 2/27/2021 2:54:30 AM. Forum started by
Bethany Callora
1872
Last answer on 1/16/2021 9:28:15 AM. Forum started by
sanyindias
4211
Selection of cement ..
PRAVEEN G
3465
Last answer on 1/2/2021 5:23:00 AM. by
pramod
2016
Regarding construction
Last answer on 1/2/2021 5:22:59 AM. by
muchbusy
AKASH SINGH
3154
Basement Water proffing
Last answer on 12/31/2020 2:46:01 AM. by
Parag Thakar
2015
Acid staining
Last answer on 11/30/2020 10:59:42 PM. Forum started by
Rohit Sharma
Right size cupola
Steel Roofing
