Home -> Forums -> Construction -> Foundation -> Steel Type
Steel Type
Tue Jun 28, 2011Total posts : 6
sumit dua
sumit dua
Topic: Steel Type
Hi
I am constructing a new house with basement, ground, first, second  floor and option for 3rd floor in future.
I am exploring different steel brands for RCC structure, foundation etc. Are brands like Kamdhenu, Rathi local brands?
Shall I go for more global brand like Tata Steel, SAIL etc or Kamdhenu/Rathi will be ok for same steel specifications.
Sumit
Wed Jun 29, 2011Post  #1
subhakankhi
subhakankhi
Post subject: Steel
Hello,
Its difficult to categories the product by their brand, as everyone's product is chemically the same (atleast in paper).
But when it comes quality product, no one can beat TATA in this segment. Its the only company to provide Fe500 in place of Fe415 and that too at the same price. TATA is the only company which sell its product in Meter measurement and not in Kg. Hence its wise for him to stick to its diameter.
Ideal weight of Steel
8 mm : 0.40 Kg/m
10 mm  : 0.60 Kg/m
12 mm :  0.90 Kg/m
16 mm : 1.6 Kg/m
If you choose TATA, you get satisfactory quality but price is more than others.
SAIL is equally good.
Thanks.
Subhakankhi.
Architect
Wed Jun 29, 2011Post  #2
sumit dua
sumit dua
Post subject: Steel
Thank you very much for the response.
Thu Jun 30, 2011Post  #3
Ajit Tareeka
Ajit Tareeka
Post subject: Tata is very expensive
Tata is very expensive. I do not think that the quality of tata is better than other local brands. They are equally good as reputed and topmost brands in steel. Although the big DLF  buildings in Gurgaon are  built using kaamdhenu and rathi.
Steel strength should be enough according to the load bearing capacity of the building. And kamdhenu and rathi are equally good.
Fri Jul 01, 2011Post  #4
sumit dua
sumit dua
Post subject: Steel
There are different views/opinions here. I am confused a bit on this. Although it's personal choice but I want to make some informed decision.
Can you please let me know the price difference between Tata Steel and Kamdhenu/Rathi steel. I want to find out whether it's worth to pay a little extra for Tata Steel?
How much will I have to pay more for Tata steel.
Sumit
Fri Jul 01, 2011Post  #5
Dear Dua
You should purchase MS Steel from any reputed firm, differance of rate have no meaning for such a big purchase. The rates of steel are varies daily, so it is of no use to now the price of today or tomorrow.
Every firm give steel on weight basises, no firm give you steel on measurement basises.
For your quarries and to know about MS Steel bars you should go to website gharexpert.com where in raw material section see steel sub section where you find lot of information about steel bars. For weight relation with length see the link below.http://www.gharexpert.com/articles/Steel-2024/How-to-ensure-weight-steel-members-_0.aspx
Sat Jul 02, 2011Post  #6
erbharathi
erbharathi
Post subject: steel
Hello,
RINL, visakhapatnam is the best steel industry for making wire rods of 8mm,10mm,12mm 16mm,20mm etc. Quality wise u always choose any branded steel only like visakhapatnam steel or tata steel. do not go for local steel because they are not mainted uniformity in dia and thier chemical composition also differes from bulk to bulk.
Foundation-Construction Questions (38)
1822
2685
Last answer on 4/26/2021 10:00:27 AM. by mohamed. Forum started by Sanjeev Thakur
13772
overlap length to steel
3207
steel
15583
4331
2217
2899
RCC Roof
3571
Last answer on 12/31/2020 2:31:50 AM. by . Forum started by Muhammad Rizwan
4940
COLUMN AND STEEL DESIGN
4940
3652
18383
2962
2220
COST OF COLUMN PER SFT
Last answer on 5/24/2021 11:15:40 PM. by JAI PRAKASH. Forum started by Ganesh
2088
what is the density of stainless steel per cum
Last answer on 10/17/2016 9:14:46 PM. by JAI PRAKASH. Forum started by SANJAY DUSANE
1836
chick door
1885
Steel Erectors
2866
Steel calculation
2684
Pillar
2140
Curing urgent
2372
structure work
5166
Pillar foundation
2204
new house
2821
building a house
1992
Construction Agreement
3091
Foundation
2272
Foundation
1477
10048
3660
Foundation
2115
Structure proof checking
2558
Foundation design
2462
2468
Saria and cement
3657
Wall Thickness
2679
3180
Type
HSD
Precautions
Steel
Steel Roofing
