Home -> Forums -> Construction -> Outdoor -> Steel calculation
Steel calculation
Mon Oct 17, 2016Total posts : 0
Vamshidharreddy
Vamshidharreddy
Topic: Steel calculation
How much steel is required for 19440 sq.ft slab area of 4" thickness of slab
4312
4779
Last answer on 1/13/2014 2:23:28 PM. by S L Gupta (Civil Engg). Forum started by balaji
15529
2204
2867
RCC Roof
4922
COLUMN AND STEEL DESIGN
4922
1953
I have constructed my house thru one of local contrctr at the rate of 1300 per s
Last answer on 12/4/2014 1:21:13 AM. by JAI PRAKASH. Forum started by mani
3182
steel
3706
2233
4931
4113
2154
R.C.C 1:2:4
Last answer on 3/18/2014 1:14:13 PM. by S L Gupta (Civil Engg). Forum started by ijazulhaq
2653
2991
2373
Tips for Aluminum Paint
Last answer on 1/16/2011 2:41:59 PM. by Swati Sharma. Forum started by Ar.chitra Tibrewal
2066
what is the density of stainless steel per cum
Last answer on 10/17/2016 9:14:46 PM. by JAI PRAKASH. Forum started by SANJAY DUSANE
1743
6661
6301
11322
10587
Life span of RBC lintel roof
2079
Foundation
3557
R.C.C. column in Sqft
2267
Plumbing works
1567
2129
New 4 storey building design
1880
earth filling under floor
1762
want a parking
2384
2255
2556
foundation plan.
Last answer on 12/15/2011 2:31:13 PM. by Ishmael Mphande. Forum started by Patrick Salasini
2606
Last answer on 12/6/2011 7:58:37 PM. by Manish. Forum started by Manish
2488
Re-Construction
2990
cracks in walls
Type
HSD
Precautions
Steel
Steel Roofing
TMT
Specification of Steel
