Home -> Forums -> Construction -> Start Construction -> Steel in Lintel
Steel in Lintel
Tue Aug 25, 2015Total posts : 5
krishna pratap
krishna pratap
Topic: Steel in Lintel
Dear Sir
Please let me know what ratio is required for steel in lintel.
The size of Roof is 36*30 Feet . how much steel is required for it .
I have plan for first floor also .
regards
krishna
Tue Aug 25, 2015Post  #1
You can use the cross pattern of 12 mm and beams of 16 mm saria.
The total saria you need is around 1.5 tonne to 1.6 tonne.
Wed Aug 26, 2015Post  #2
krishna pratap
krishna pratap
Thank You Jai Prakas Sir,
Please tel me what is difference between Latak Beam ad Hazmi Beam (Beam under the roof) which one is better .
My Contractor said I will give all beam under the roof with same sarya as in Latak beam . Pease suggest .
He suggest sarya size .
12 MM at 7" and 10 MM at 5"  distance  . and crank sarya 10MM  between every 7'' . is this is okey pls suggest.
Krishna
Wed Aug 26, 2015Post  #3
Dear Krishna partap
      Latak beam  means the beam under roof and hazmi beam means beam in roof. Latak beam have more strength than hasmi beam in slab. Contractor wants to lay hazmi beams because shuttering material and labor is more in latak beam.
For slab use 12mm steel bars at 7''c/c or 10 mm at 6''c/c..
Wed Aug 26, 2015Post  #4
krishna pratap
krishna pratap
Dear Gupta Sir,
Thanks for your valuable suggestion , Please let me know what is the meaning of Crank lintel , and total sarya required for 36*33 feet covered area.
With Regards
Krishna
Wed Aug 26, 2015Post  #5
Your contractor is correct.
5692
2195
quantity required for Tor steel Lintel
Last answer on 6/30/2012 8:58:33 AM. by Gunjan Utraja. Forum started by ndmalam
3152
Steel in Lintel
Last answer on 7/4/2020 3:06:52 AM. by JAI PRAKASH. Forum started by krishna pratap
1171
2217
2899
RCC Roof
4331
15584
2681
My House design
2870
FOR 250 SQ FT R-B-C SALB RATE
6471
4133
1970
Last answer on 12/5/2015 11:13:14 AM. by S L Gupta (Civil Engg). Forum started by Rohit Sharma
9197
4940
COLUMN AND STEEL DESIGN
4940
3207
steel
3721
4127
3312
2236
2312
2061
Types of arch
Type
HSD
Precautions
Steel
Steel Roofing
TMT
Specification of Steel
