Home -> Forums -> Construction -> Start Construction -> Steel in Lintel
Steel in Lintel
Wed Aug 26, 2015Total posts : 6
krishna pratap
krishna pratap
Topic: Steel in Lintel
Thank You Jai Prakas Sir,
Please tel me what is difference between Latak Beam ad Hazmi Beam (Beam under the roof) which one is better .
My Contractor said I will give all beam under the roof with same sarya as in Latak beam . Pease suggest .
He suggest sarya size .
12 MM at 7" and 10 MM at 5"  distance  . and crank sarya 10MM  between every 7'' . is this is okey pls suggest.
Krishna
Wed Aug 26, 2015Post  #1
Dear Krishna partap
      Latak beam  means the beam under roof and hazmi beam means beam in roof. Latak beam have more strength than hasmi beam in slab. Contractor wants to lay hazmi beams because shuttering material and labor is more in latak beam.
For slab use 12mm steel bars at 7''c/c or 10 mm at 6''c/c..
Wed Aug 26, 2015Post  #2
Gupta Sir is always correct.
We prefer Latak beam in cases where the roof height is more e.g. in commercial buildings. It rarely needed in residential building of your size and design. It is required when we have more open area between 2 columns or walls in a building. So not a concern in a small residential project.
Thu Aug 27, 2015Post  #3
krishna pratap
krishna pratap
Dear JP Sir/ and Gupta Sir, Please let me know my plot size is 33X30 , I am giving Latak beam at border and Hazmi Beam in Slab as per required is it correct .
please suggest .
Krishna
Thu Aug 27, 2015Post  #4
Dear Kirshan
          The arrangement of latak beam alround and hazmi beam in room slab is good arrangement. Go ahead for laying slab of your dream home.
Thu Aug 27, 2015Post  #5
krishna pratap
krishna pratap
Thanks Gupta Sir,
Please let me know in future I have plan for first floor .
please suggest ..
regards
krishna
Thu Aug 27, 2015Post  #6
Please go ahead now and in future for FF as well if you have the same floor plan on FF as well.
5692
2195
quantity required for Tor steel Lintel
Last answer on 6/30/2012 8:58:33 AM. by Gunjan Utraja. Forum started by ndmalam
3451
Steel in Lintel
Last answer on 8/26/2015 6:45:44 PM. by JAI PRAKASH. Forum started by krishna pratap
1170
2216
2899
RCC Roof
4331
15583
2681
My House design
2869
FOR 250 SQ FT R-B-C SALB RATE
6471
4132
1970
Last answer on 12/5/2015 11:13:14 AM. by S L Gupta (Civil Engg). Forum started by Rohit Sharma
9196
4940
COLUMN AND STEEL DESIGN
4940
3207
steel
3721
4126
3312
2236
2312
2061
Types of arch
Type
HSD
Precautions
Steel
Steel Roofing
TMT
Specification of Steel
