Home -> Forums -> Construction -> Steel -> Steel prices Rathi/ Tata
Tue Feb 19, 2013Total posts : 1
Pawan Rao
Pawan Rao
Topic: Steel prices Rathi/ Tata
Gupta Sir,
Could you also please confirm the current steel bar prices in Gurgaon for foundation column work for :
16 MM
12MM
8MM
Just wanted to have the rough idea before I approch the dealers.
Thanks again !!
Fri Feb 22, 2013Post  #1
DearRao
      The rates in the market are changed day to day dealing and this exercise to know about the rates must be done by your self in the market.
Steel-Construction Questions (39)
3207
steel
13268
Steel Type
4950
15583
2328
3074
Steel
2468
Saria and cement
2980
Last answer on 7/25/2010 8:10:57 PM. by R.Manikandan Pillai. Forum started by sunilrathi86
4331
2217
2899
RCC Roof
2861
Selection of Steel for home construction
Last answer on 2/18/2013 11:37:36 AM. by S L Gupta (Civil Engg). Forum started by sunny420
21331
how much cement is required for 100 sq wall for plastering and brick work.
Last answer on 3/14/2013 2:12:10 PM. by S L Gupta (Civil Engg). Forum started by paresh
1601
sir/madam give tell about loadbearing banhkam as for 8 room roof is an tata 12 f
Last answer on 8/8/2011 4:24:14 PM. by S L Gupta (Civil Engg). Forum started by megha jadhav
2407
Specification of Water
Last answer on 12/31/2020 2:40:46 AM. by SHEIK. Forum started by AYYAZ SHAIKH
1825
i am building my house.should i go for tata/sail or local ones like kamdhenu/amb
Last answer on 4/2/2016 1:13:17 PM. by Praveen. Forum started by prasad K
4940
COLUMN AND STEEL DESIGN
4940
28823
latest price of building materials in bangalore
Last answer on 10/10/2010 12:44:43 PM. by rudresh. Forum started by manjuks
2685
steel requirment
15583
1992
Residential complex
4370
RCC Columns
3239
7480
Bar Bending Schedule Software
2523
steel
29942
2613
9363
2262
Current iron rod price
2606
1885
Steel Erectors
2382
3268
13774
overlap length to steel
2161
2539
Type
HSD
Precautions
Steel
Steel Roofing
TMT
Specification of Steel
