Fri Aug 17, 2012 | Post #1 | S L Gupta (Civil Engg)
The MS Steel bars required for construct your dream house is 3000 KG approximately . | |
Sun Aug 19, 2012 | Post #2 | amzad
Join date: Nov 2011 | thank you Gupta sir for the answer, I was estimating the cost of construction and stuck on the steel. Now i am through with one part of it, can you guide me for the second query of which stregth steel bar would I be needed if i want to construct first floor. | |
Sun Aug 19, 2012 | Post #3 | P. Panchal
Join date: Apr 2011 | for calculating type of bar, Now that require detailed plan.
Mon Aug 20, 2012 | Post #4 | S L Gupta (Civil Engg)
use 4nos,16 mm dia bars in columns
Use 10 mm dia bars in RCC slab @ 6'' center to center. | |
Tue Aug 21, 2012 | Post #5 | amzad
Join date: Nov 2011 | Thanks Gupta Sir. Now I can calculate the amount and cost of steel required for my house. I really appriaciate your help on this topic.. thanks a ton. | |
Raw Material-Construction Questions (38) | |
