Home -> Forums -> Construction -> Start Construction -> Steel rod size For column and Tie beam structure
Tue Mar 19, 2013Total posts : 10
Jitendra Sindhi
Jitendra Sindhi
Topic: Steel rod size For column and Tie beam structure
Dear Mr. Gupta
I am planning to construct my house G+2 on 1200sqft plot.Architact Suggested pillar size of 9x 9 inches and 15 Nos of pillars. Please suggest me steel rod size and nos.for pillars.
Please Also suggest no of steel rods and size(Dia) for Tie beam.
Tue Mar 19, 2013Post  #1
DearJitendra
        The MS Steel rod/ bars are calculated on the basis of load taken by the pillar/ column and span between the column etc. Your architect provides 15 nos columns in your plan. Use 4 nos 16 mm dia bars with 8mm dia rings or ties 6'' center to center.For more detail and knowledge visit gharexpert.com website construction section in which in concrete sub section you will find lot about column and concrete. Spent time read articles give lot of knowledge about construction, See the link below.
http://www.gharexpert.com/articles/Cement-Concrete-1644/Column-Frame-Structure-Building_0.aspx
http://www.gharexpert.com/articles/Cement-Concrete-1730/Mild-Steel-Bars-in-Cement-Concrete_0.aspx
Mon Mar 25, 2013Post  #2
Jitendra Sindhi
Jitendra Sindhi
Post subject: MS rod size for Pillar
Thanks for your Prompt Response and i have also gone through both Articles very infomative.
Please also suggest
1. What should be minimum distance between two plillar?
In my case architact has given distance 13feet 8 inch and size of pillar is 9X9 SQINCH
2.What should be MS rod size for these pillar.
3.
Tue Mar 26, 2013Post  #3
Dear Jitendra
         The distance between the pillars are according to site conditions. There are no any rule for minimum distance.
Use at least 6 nos 16 mm bars in the coolmns.
Thu Mar 28, 2013Post  #4
Dear Jitendra
                For architect plan and better arrangemet of space according to your requirement, columns marking etc please drop an email to support@gharexpert.com for better solutuin of your query.
Fri Mar 29, 2013Post  #5
Jitendra Sindhi
Jitendra Sindhi
Thank You Sir
Mon Sep 12, 2016Post  #6
Deep Kumar
Deep Kumar
Post subject: 9X9 columns
Dear Mr. Gupta,
 i have planing to build a house and the total area is 512
sqft could you please let me know how much steel do i need to buy for the roof. and i will put 4 columns in there these will be 9x9, thank you.
Tue Sep 13, 2016Post  #7
  Dear Deepak
     For roof 500 to 600 kg MS Steel is required.
Wed Oct 17, 2018Post  #8
Sat Jun 29, 2019Post  #9
Sonu Adak
Sonu Adak
Post subject: Piller details for G+3 House 500sqft
I have foundation of my 500sqft House with 4 ms rod in 10x10 in dia. Can i construct G+3 with these foundation and piller ?
If not please suggest the right one.
Tue Dec 31, 2019Post  #10
syed
syed
dear mr.gupta
                       iam planning my house for g+4 construction and my column size is 9"×15 " .. total area is 1800 sft  with 20 nos of columns .and spacing b/w columns is 3-5mtrs.....its already constructed g+3 ie 4 slabs done... can i plan for 5 slab??? for total g+4 constrution... sugest me sir.
2824
4800
tie beam obsolete
8652
2583
Re. eccentric footing.
Last answer on 12/6/2013 12:11:41 PM. by S L Gupta (Civil Engg). Forum started by vignesh_mp
10048
6549
2037
2708
2303
2034
13772
overlap length to steel
2687
Steel Size
Last answer on 8/21/2014 12:31:17 PM. by S L Gupta (Civil Engg). Forum started by ferous
1620
Residential Structural needs
Last answer on 10/5/2016 12:15:38 PM. by S L Gupta (Civil Engg). Forum started by Padmanabhan
2144
About column and beam structure
Last answer on 1/4/2019 11:39:23 PM. by S L Gupta (Civil Engg). Forum started by Rana kachari
5663
Column and beams specification for 5-7 floor house
Last answer on 8/7/2011 5:52:06 PM. by timm todd. Forum started by timm todd
3134
722
3033
3312
2236
2312
2061
Centering
Type
Earthquake
