Layout and House Plans
Structural drawing required
Fri May 24, 2013
Saifur Rahman
Topic: Structural drawing required
Hello! I'd like to build a 2 storied residential building. It could be brick building with RCC roof since I'd prefer to minimize cost. It's very small in size (land area: 26' X 46'). I've also attached a preliminary layout of the plot. It'd really be my pleasure if anyone send me a proposed layout. Sincere thanks.
Earth Excavation Layout.docx on Fri May 24, 2013,&n
Sun May 26, 2013
Post subject: Structural Design need Details....
Dear Mr.Saifur Rahman , As you mentioned,It is a brick building,kindly make it clear that 1. Is there a R.C.C.plinth beam ?
2.What are the thickness of various Brick walls above and under plinth level.and its depth?
3.What will be the Height of walls under roof slab?
4. If your site is within Earthquake Zones of India,then kindly contact an qualified Structural Engineer,
Mon May 27, 2013
Dear Rahman
Construct 9'' thick load bearing wall and lay RCC slab on walls.
2971
i need structural details and estimation for 150yd plot
Last answer on 8/17/2012 11:36:21 AM. by
gangula
2149
how to read structural drawings//Basic steps??
Last answer on 8/27/2015 6:43:26 PM. by
Maryanne Robynn Delana
1997
Hie
Last answer on 7/3/2020 11:37:56 PM. by
1816
hi,i have a basic drawing but not structural drawing and electricity and plumbin
Last answer on 12/14/2012 11:53:05 AM. by
ashu
2377
Last answer on 4/4/2010 11:44:47 AM. by
dillip rout
2115
Structure proof checking
Arnab Ghosh
1385
i want home plan for area length- 35X24' Required- 1 drawing room , 3 room etc.
Last answer on 11/30/2016 12:55:38 PM. by
Sandeep
1639
dear sir, we are required 17x38 plot area ground flor with parcking space, kitch
Last answer on 12/15/2016 2:04:30 PM. by
vijay
2182
Last answer on 7/3/2020 10:55:46 PM. by
sridhar
3721
Last answer on 2/22/2021 2:25:37 AM. by
Mohiuddin
2567
roof of a building
Last answer on 7/3/2020 11:28:49 PM. by
sujata
11692
Last answer on 2/2/2022 12:01:14 AM. by
meenakshisundaram
2048
I'M IN NEED OF MS WORKSHEET FOR STRUCTURAL DESIGN
Last answer on 8/24/2021 2:39:40 AM. Forum started by
martin kevin red
6162
i want structural design of staircase in area 3.00mx 2.20 m
Last answer on 5/3/2014 7:45:54 PM. by
sudipta das
2390
Last answer on 7/29/2014 12:45:59 PM. by
MANJUNATH
2019
foundation drawing required
Last answer on 8/10/2016 12:58:23 PM. by
AD
3091
Last answer on 7/26/2009 8:35:08 PM. by
Ganesh
cosntruction novice
1605
VASTHU FOR HIGH RISE STRUCTURES...SAY 6 ,8,10 STOREYS OF AN APARTMENTS OR OFFICE
Last answer on 4/7/2011 1:38:52 AM. by
D.Ramachandran
2213
Last answer on 12/14/2010 7:35:48 PM. Forum started by
Rakshit
2691
Raj
2188
Amutha
2184
vanramr
2793
raghu
4520
Nitien Parmar
suryarao p
1890
santosh
2284
Deepak Giri
2266
ajay sharma
2767
u v sudhakar
3464
ramana
2356
srinivas kamsali
1968
tanaya483
2242
ramanapeddu
3595
SRIKANTH.S
2324
HIRA SINGH
2792
Alexander Graf
Mohiuddin
1548
uma shankar
2114
mohammedbasha
How to design a house on theme
Theme designing is slowly but steadily picking up steam. Designers today are very particular about the 'idea' behind a s
Interior Decoration Ideas for Drawing Room
The space matters a lot while decorating a room. Before decorating and furnishing your room, decide how much time your..
Drawing room Ceiling Design
A drawing room ceiling can change the interior of your room. Beautiful ceiling designs and colorful ceiling can be the..
Drawing Room Flooring
