Home -> Forums -> Construction -> Start Construction -> Structure drawing - Is it OK ?
Sat Jun 04, 2011Total posts : 2
manjuks
manjuks
Topic: Structure drawing - Is it OK ?
I have constructed approx 1000 sft -2nd floor independent house on existing building on 30' (N-S)x40' (East -west) - going for walls above walls and no pillars.
I have enclosed a hand drawing showing the concealed beams (12mm rods), steel rods (10mm-50 rods along West to east, 8mm rods- 55 rods North-south)  laid for RCC Mold casting.
I intend to go for a room with attached bath room of diemnsion 12'x15' on 3rd floor above MBR shown in the drawing(south west).On this room it is proposed to put 3 nos of 1000 Ltrs storage PVC Tanks.
I need following clarifications :
1.With the qty of steel rods put for RCC Mold - takes the load of one more room & storage tanks in south west ?
2.How many days we need to put water for curing on mold ?
3.After how many days from mold casting day- we can remove the centering, shuttering supports.
Thanks in advance.
from
manjuks
Attachments: structure-draw-2ndfloor.pdf on Sat Jun 04, 2011,&n
Mon Jun 06, 2011Post  #1
Dear Sir
            ! You have to construt a room with bath room at 2nd floor. put 12mm dia rod 6'' centre to centre on both side because they have to take load of roof and water tank. Put the water tank staggered near the walls.
2. Atleast water should be filled for 10 days on RCC slab after it water should be sprinkeled for a week.
3.Take 10 days for removing the shuttering.
Thu Jun 09, 2011Post  #2
P. Panchal
P. Panchal
Hi
It's better to take professional help because its an old building and not a RCC building. care should be taken
2372
structure work
1757
structure work
Last answer on 8/20/2016 12:45:01 PM. by S L Gupta (Civil Engg). Forum started by manish agarwal
1672
structure work
Last answer on 8/20/2016 12:43:48 PM. by S L Gupta (Civil Engg). Forum started by manish agarwal
2066
Can u please tell me what should be the form and structure of a drawing room
Last answer on 9/19/2011 8:37:44 PM. Forum started by Ruchi Shrivastava
2115
Structure proof checking
1584
Hi i m uploadimg my house plan n structure drawing ..i would like to know its go
Last answer on 8/31/2016 3:15:02 PM. by freekundli. Forum started by manish agarwal
4287
waterfall In Drawing room north wall . is it OK AS per Vasthu
Last answer on 8/10/2010 12:42:06 PM. by vimal. Forum started by bhargavi
2971
i need structural details and estimation for 150yd plot
Last answer on 8/17/2012 11:36:21 AM. by Gunjan Utraja. Forum started by gangula
2196
1570
2330
1180
Does polyester shrink when it's washed and dried?
Last answer on 1/23/2022 6:06:52 AM. by Celly Swehykol. Forum started by Rolly
2878
2635
paiting
Last answer on 7/3/2020 11:21:56 PM. by Gunjan Utraja. Forum started by Abraham
13267
Steel Type
2969
NEED A ADVICE ABOUT EAST FACING PLAN
Last answer on 7/3/2020 9:50:41 PM. by JAI PRAKASH. Forum started by chandru
3241
It's very urgenti am constructing a house in hyderbad.East face plot(36*50)36 wi
Last answer on 10/4/2021 9:18:14 AM. by madhusudan. Forum started by varala prasad babu
1646
I am planning to buy a flat. It's main door opens to South. Is it ok to buy this
Last answer on 7/24/2011 1:20:56 AM. by sabina vanjani. Forum started by Nikhil Alekar
2212
3310
2312
Earthquake
How to design a house on theme
Theme designing is slowly but steadily picking up steam. Designers today are very particular about the 'idea' behind a s
Termite Control
Interior
Interior Decoration Ideas for Drawing Room
The space matters a lot while decorating a room. Before decorating and furnishing your room, decide how much time your..
