Home -> Forums -> Construction -> Foundation -> Structure proof checking
Thu Aug 21, 2014Total posts : 2
Arnab Ghosh
Arnab Ghosh
Topic: Structure proof checking
Can anybody certify the structure drawings after proof checking and suggest the changes required if any the structure is designed for g+3.
Attachments: bamdauli_recover D-Size Layout (10).pdf on Thu Aug 21, 2014,
bamdauli_recover D-Size Layout (17).pdf on Thu Aug 21, 2014,
bamdauli_recover D-Size Layout (3).pdf on Thu Aug 21, 2014,
bamdauli_recover D-Size Layout (1).pdf on Thu Aug 21, 2014,&n
Thu Aug 21, 2014Post  #1
Dear Ghosh
            Please contact any structural engineer for this job.
Mon Oct 13, 2014Post  #2
even if the steel laid for slab is ready without physical checking by engineer you must not cast the slab.
Foundation-Construction Questions (38)
2738
3810
ROOF WATER PROOFING / TANKING
1946
2747
2319
1872
check this
Last answer on 7/14/2010 6:48:24 PM. Forum started by nayma
1926
Last answer on 5/24/2012 5:08:53 PM. by S L Gupta (Civil Engg). Forum started by gaju
1877
point to be check befor tile application
Last answer on 9/12/2013 12:12:08 PM. by S L Gupta (Civil Engg). Forum started by archi
845
Last answer on 1/27/2022 6:31:12 PM. Forum started by Rahul T Pal
2057
Last answer on 4/6/2016 11:43:24 AM. by S L Gupta (Civil Engg). Forum started by zakia sultana
2132
i need the term related with damp proof and its treatment
Last answer on 8/29/2012 5:01:18 PM. by S L Gupta (Civil Engg). Forum started by abhijeet joshi
2214
2195
2227
2053
Can u please tell me what should be the form and structure of a drawing room
Last answer on 9/19/2011 8:37:44 PM. Forum started by Ruchi Shrivastava
2188
method of road structure, step wise detail caculation of material
Last answer on 3/15/2011 6:14:15 PM. by kanwer sajjad. Forum started by kanwer sajjad
2606
COLUMN nd LOAD BEARING
2692
home security systems
Last answer on 7/3/2020 10:55:36 PM. by S L Gupta (Civil Engg). Forum started by farrukh tahir
2203
Company and Cost of Solar panels for 3 storey building
Last answer on 7/3/2020 9:55:28 PM. by S L Gupta (Civil Engg). Forum started by sowmya
2661
Pillar
2128
Curing urgent
2347
structure work
5153
Pillar foundation
2182
new house
2807
building a house
1981
Construction Agreement
3084
Foundation
2261
Foundation
1466
10031
3648
Foundation
2548
Foundation design
2435
2458
Saria and cement
3636
Wall Thickness
2661
3153
13249
Steel Type
Earthquake
Damp
Damp Proofing
Protect
Check width and depth of the channel, the quality and size of the bricks for mechanical protection.Whether cable ident..
Fire
Guideline for laying DPC
