Home -> Forums -> Construction -> Water -> Submersible pump - Bore
Tue May 25, 2010Total posts : 1
Giri
Giri
Topic: Submersible pump - Bore
Dear All..
We reside in Hyderabad. We have recently drilled a 4.5" bore at our house which is under construction. We got water at around 160 ft. Bore was drilled to 220 ft. There is enough water. We were told that submersible motor is better.
1. How do we decide what HP motor / pump is appropriate for the purpose ?? Is that the HP of the motor is decided by to which floor we need to take the water to ?
2. Can some one suggest which is the good make pump that can be used ? Is Lubi make pump alright for the application ?
3. With in how many days after bore is drilled, pump / motor need be connected ??
Wed May 26, 2010Post  #1
Dear Giri
For deciding the motor/ pump you should take at least 3 stories provision of the house which is beneficial in the long run. Take pump of any standard/ repudiated company which are available in your area, after studing of his manufacture card and keep with you warranty/ guaranty card and bill. After development of tube well i.e. when slush and muddy water clear from the bore well and fresh water started to come out then pump/ motor may be lowered with consultation of tube well mechanic
1949
please tell me which direction is suitable (good) for submersible
Last answer on 12/31/2020 1:21:42 AM. by Pinky Mathur. Forum started by vinod
1590
borewell
Last answer on 3/16/2014 5:41:40 PM. by Ahmed. Forum started by paresh
947
How to pump wow to 60-70 leveling in a short time?
Last answer on 2/20/2022 8:22:09 PM. Forum started by aglar
1794
Prtotect Cast Iron Cover on underground Tank & Manhole from Theft
Last answer on 10/25/2013 12:34:54 PM. by S L Gupta (Civil Engg). Forum started by Viral
2545
Is this plan vastu compliant
Last answer on 7/3/2020 11:50:24 PM. Forum started by timm todd
2773
suction pipe length for sump motor
Last answer on 1/5/2022 8:30:40 PM. Forum started by manjuks
7257
2616
COLUMN nd LOAD BEARING
2256
1261
Is ground water from bore well suitable for construction?
Last answer on 9/9/2016 11:06:16 PM. by bhuvaneshwaran bn. Forum started by Sandeep
1782
i am born in 08/04/1988 pls inforn how to i work in office and how to lead life.
Last answer on 5/12/2015 2:39:04 AM. by JAI PRAKASH. Forum started by shivaprasad
7927
2212
858
4925
LOAD BEARING STRUCTURE
4132
1764
1879
in as house well was in SW..but a new BORE was taken in NE..will this compensate
Last answer on 3/25/2011 12:53:49 AM. by sabina vanjani. Forum started by D.Ramachandran
2530
Position of Kalpavirkha to be planted in east facing house & boring position of
Last answer on 7/3/2020 10:44:47 PM. Forum started by RAJ KUMAR KALIA
3177
Sump construction
2139
Question Regarding Borewell
1967
Over Head Water Tank
2756
Salt water
3128
Importance of Water
10179
2494
1887
water tank motor capacity
2358
2548
Water for Construction
Fountain pumps for the garden
The pump is at the heart of the fountain. There is always a limit to the height to which a pump can push water. As this
Fountain care
Fountain in home is just like a bonus with the salary. And if it is in the front of your house or in the garden it is un
Pool Pumps
Pool heaters
Pool
Pool Heaters
You spend a lot of money to construct a swimming pool and on its other equipments. But if your pool is frequently too ..
Electricity
Electricity Consumption of Various Appliances
Saving electricity not only adds to your money but will help thousands in demand of energy also.It’s duty of every cit..
