Home -> Forums -> Construction -> Plumbing -> Suction pipe lengh of the sump motor
Wed May 15, 2013Total posts : 1
sam_m400
sam_m400
Topic: Suction pipe lengh of the sump motor
How much is the distance of Head of suction of a sump motor
which is of 1 HP ? I have been told by texmo dealers that 1HP motor will serve though mine motor point is 25 feet away from the sump .Suguna dealers mentioned it won;t work. could anybody help on this?
Thu May 16, 2013Post  #1
Hi: Generally 1HP centrifugal pumps (single stage) can manage more than 25 feet very easily, however, the suction head should remain close to 20 feet and the rest height should be made as delivery head. In specialized requirements such as agriculture, wells and sewage; ejecto pumps (jet pumps) are used. They are capableof lifting water upto100ft deep.
Install the suction pipe in a vertical position and not slanting.
2772
suction pipe length for sump motor
Last answer on 1/5/2022 8:30:40 PM. Forum started by manjuks
1561
front 30ft back 29ft.lengh 76
Last answer on 2/25/2015 9:12:36 AM. by seema tyagi. Forum started by raman kumar
2195
Last answer on 12/31/2020 8:58:35 PM. by S L Gupta (Civil Engg). Forum started by Joseph Santhosh
2100
2406
Specification of Water
Last answer on 12/31/2020 2:40:46 AM. by SHEIK. Forum started by AYYAZ SHAIKH
1438
Basic Details:I am going to dig a borewell for 3 storied house construction and
Last answer on 1/17/2018 11:49:03 PM. by S L Gupta (Civil Engg). Forum started by Shekar Nair
2931
1988
PLUMBING
2230
sewage pipes
2533
what happens when sump comes at north east corner inside the room
Last answer on 7/3/2020 10:54:04 PM. by S L Gupta (Civil Engg). Forum started by vedamurthy
3497
10177
1636
West face House, can we construct North west side face sump
Last answer on 7/4/2020 2:50:11 AM. by S L Gupta (Civil Engg). Forum started by G.Mallikarjuna
3370
13537
9174
2177
can waste pipe pass the inner maingate ?
Last answer on 12/31/2020 2:33:37 AM. by S L Gupta (Civil Engg). Forum started by ankit gupta
3267
2341
what is the diffrence between u-pvc ans pvc pipes
Last answer on 7/31/2014 7:59:31 PM. by GUNA. Forum started by SANJAY DUSANE
6270
Water Tank Quality
3114
Hot Water Tank
2914
Sand in Water
3380
Diverters for Bathroom
2561
2145
40516
2083
GI pipe Vs CPVC pipeline
2931
1755
2080
Toilets
1988
Wall mounted cummod vs normal
5055
2775
2388
3074
Swimming pool
2541
water softner
2682
commode type and flush type
4193
to shut off water to house
Vastu for Water Tank
Sewerage
Sewerage & Plumbing System
General
Various
