Tue Jan 10, 2017 | Total posts : 3 |
| Topic: Suggestion on foundation building
Dear Sir,I am considering buying land for house building. It is in Earthquake level 4 zone. Also, I see that the level of plot is around 5.5 feet below the level of road. I do not plan to construct any basement there. Please advise on following: - What kind of material should be used to fill the plot, in order to bring it up to level of road? Can soil (earth) be used there? - In case of soil, whether any tests to be done on the soil being filled? - What kind of foundation is recommended for this case. Thanks/regards. |
Tue Jan 10, 2017 | Post #1 | S L Gupta (Civil Engg)
Join date: Mar 2008 | Dear Sandeep, Strip foundation is good, but take the structural design from structural engineer with respect to bearing capacity of soil. For filling see
In Earth filling the earth should be free from all roots, grass,
shrubs, rank vegetation, brush wood, trees, saplings, rubbish, salt and
foreign material/ matter. Earth should be free from stone pieces, kankar
etc because these objects hinder proper compaction of soil manually or
mechanically. The earth should also be free from salt or kallar and
alkaline materials.
Earth brought from cutting should be directly used in filling. Earth
should be free from clouds if exist should be broken during lying of
earth. At the time of laying/ filling the earth should be laid in
regular horizontal layers each not exceeding 20 cm in depth. All lumps
or clouds exceeding 8 cm in any direction should be broken. Each layer
should be watered and compacted manually with steel rammer or
mechanically with ½ tone roller. Where specified every third and top
layer should be consolidated with power roller of minimum 8 tones. The
top and sides of filling should be neatly dressed.
Plinth Filling or filling under floor:
In case of filling under floor or plinth filling or filling around
masonry needs special attention because in these cases one cannot
compact/ consolidate the soil with the help of mechanical means i.e.
with power roller. Filling under floor or plinth filling or filling
around masonry should be similarly done with earth in layers not
exceeding 15 cm, watered and consolidated by ramming with iron rammers
and with butt ends of crowbars, before the succeeding one is laid. Only
sandy soil, free from salts, organic or foreign matter and white aunts
shall be used for such filling. Where there is black cotton soil, it
shall be removed to a depth of 60 cm as it is liable to absorb moisture
and expand thus damaging the floor. The top 30 cm immediately below the
floor shall be sand or cinder.
To prevent future sink age and damage to the floor it is necessary,
when convenient to do so, that the plinth area is flooded with water for
about 24 hours to enable earth filling to consolidate thoroughly. In
this case, earth filling should be allowed to dry and then rammed and
consolidated, before the flooring is laid.
Tue Jan 10, 2017 | Post #2 | S L Gupta (Civil Engg)
construction if we spent some time about design, specification and
quality of construction than there is lot of improvement one can find in
construction. gharexpert.com website provide maximum engineering detail relating to construction if one have time and read these. Visit again for any problem relating to construction. | |
Ground work-Construction Questions (39) | |
Articles that might interest you! | | Designing a Foundation Foundation is the part of structure below plinth level and needs special care while designing. Whole design of the fou.. | | Demarcation/layout Procedure Baseline is marked on the ground either from centre line of the road or from any permanent building nearby | | Which Are Various Reasons of Cracks in Buildings? Cracks can happen due to foundation movements and settlements of building, thermal movements, chemical reactions, elas.. | | Basement Walls Basement walls always needs special care because of outside pressure of soil. Read about What care should be taken for.. | | Guideline for Labor for Brick Work Foundation We all know the importance of brickwork in any construction, So the article here describes the guideline meant for la.. | | Which type of soil and foundation is recommended for protection of building in earth quake zones? .Loose fine sand, soft silt, black cotton soil and expensive clays should be avoided for foundation. If unavoidable th.. | | Column and Frame Structure Building Columns are used to support the beam or roofs and transfer the load to the earth. These serve the decorative purpose a.. | | Orientation of Building To get maximum ventilation and natural light in your house, make sure the building is properly oriented. Orientation o.. | | Specification of 'Bricks Walls' Strong brick walls are a symbol of strong building. Whole construction process somewhere depends on it. So here is a b.. | | Building New Home V/S Buying Builder Flat Buying a builder’s flat may be costlier for you rather than building a new home. But if you plan to make your own, you.. | | What are various types of glasses used in doors? Types of glasses used in doors-Clear window glass, Plate glass, Prism glass, Quartz glass, Processed glass....... | | What are advantages and disadvantages of folding doors? Advantages of folding doors- Easy to install,washable, durable, superior sound damping. Disadvantages-sensitive to har.. | | What are various designs available in wooden doors? Designs available in Wooden doors..... | | What is standard size of internal folding doors? Size, Thickness and Weight of Internal Folding Doors....... | | What affects the life of doors? What can we do to increase the life of the Wooden doors? Tips to increase the life of Wooden doors.... | | What is the standard size of frame for Plastic/PVC doors? Plastic Door frame size carrying one or two shutters...... | | What are various frames recommended for Plastic/PVC doors? Frames for Plastic Doors.......... | | Which place is appropriate for sliding door? Appropriate places for sliding doors-Bathrooms, Backyards, Commercial structures........... | | What are various frames recommended for glass doors? Frames for Glass Doors-Wooden frames, Steel frames, Aluminium frames...... | | Which place is appropriate for folding doors? Appropriate places for folding doors-Homes, Offices, Guest rooms, gives attaractive and stylish look........ | | What are the various accessories recommended for folding doors? Accessories for folding doors- Door Handles, Door Fasteners,Door Viewers....... | | What affects the life of doors? What can we do to increase the life of the Plastic/PVC doors? Tips to increase the life of Plastic doors.... |
