Sunken toilet
Sunken toilet
Mon Jun 08, 2015
manjula
Topic: Sunken toilet
Hi, we are constructing a ground floor house, in which we are going to do the DPC after plinth beam, my question is do we need to sunken the toilet slab as we are going to western commode...please tell me whether toilet to be sunken or raised above the floor level...which is gud???
Mon Jun 08, 2015
Dear Manjula
The sunken floor is needed when you have to provide Indian WC In case if you want to fix western WC than no need of sunken floor to be taken at roof level in slab.
Mon Jun 08, 2015
manjula
Sir, toilet is in ground floor...
Mon Jun 08, 2015
gurkirpal singh
Check if the D.P.C is above ground level because if it is below ground line and filled with earth moisture will get passage through earth (mud) into wall. The purpose of D.P.C will not be solved you will get dampness in your walls even after providing D.P.C.
Next
The sunken slab is needed where you face problem in installing the plumbing fittings usually on upper floors. On ground floor you have plenty of the space where you can install the fitting. so there is no need to provide sunken floor. Just have a level difference in finished floor of half an inch with adjoining room will provide water barrier.
Do let me know if this provides an answer to your problem.
Mon Jun 08, 2015
Post #4
manjula
Thanks for your answer...DPC is above ground level hope its safe...
Tue Jun 16, 2015
Post #5
Go Ahead.
2156
Sunken slab
Last answer on 1/17/2021 5:51:16 AM. by
freekundli
Bhaskara
3678
sunken slab
Last answer on 7/3/2020 11:00:06 PM. by
Can we construct toilet without sunken area ? If yes, how to do it.
Last answer on 7/4/2020 1:57:51 AM. by
GUNA
Kapil Singhal
3633
sunken slab
Last answer on 1/5/2022 2:15:53 AM. by
amog
2251
hi sir,here is the toilet layout for a house im doing...is there a need for a su
Last answer on 4/12/2015 6:07:10 PM. by
amog
2939
Last answer on 10/5/2016 11:34:14 AM. by
arun
arun
2119
suppose i take all water pipes through sunken area along the length and breadth
Last answer on 7/23/2011 2:18:10 AM. Forum started by
D.Ramachandran
2338
Related to Sunken Slab
Last answer on 10/25/2015 8:30:24 PM. by
SOUNAK SAMANTA
1640
i have plan for 16'0"x55'0" plot NS 16'0" EW 55'0" one car parking two
Last answer on 12/5/2016 11:41:16 AM. by
saravana prabu
1575
toilet in south west area of house, is it bad,what are remedies to correct it
Last answer on 12/23/2016 11:16:11 AM. by
sonia agarwal
1814
Is it advisable to have bath cum toilet in agneyam or near kitchen
Last answer on 5/27/2019 1:12:18 AM. by
shreenivas
1984
One guest room,two attached bedroom,kitchen,toilet,puja room
Last answer on 10/21/2015 11:53:56 AM. by
anup Kumar
2683
Last answer on 1/10/2022 11:40:17 PM. by
vaishali
1830
where is toilet when our home facing is north
Last answer on 12/9/2014 10:19:24 AM. by
rajeev sharma
3664
CAN WE CONSTRUCT COMBINED BATHROOM AND TOILET IN NORTHWEST
Last answer on 5/31/2014 11:05:07 PM. by
Can we share a wall beetween kitchen and combined bath/toilet
Last answer on 6/2/2014 11:42:37 AM. by
RAJESH
3647
vaastu for east facing plot where should the toilet constructed
Last answer on 3/5/2021 3:03:04 PM. by
nilu
vankamardi
1940
behind my poojaroom toilet is there is it inauspicious
Last answer on 8/6/2010 9:59:12 PM. by
Rashmi
shubha
3602
What can be done to remedy toilet and bath in north east
Last answer on 8/12/2010 4:21:43 PM. by
Sathya
2479
Bathroom Cleaning Tips
Bath Accessories
Bath accessories are the essential elements of bathroom. They give new look to the bathroom and add to the beauty and ..
