Home -> Forums -> Construction -> Plumbing -> Swimming pool
Swimming pool
Tue Oct 30, 2012Total posts : 1
rajesh
rajesh
Topic: Swimming pool
hello sir i wish to construct an swimming pool in my house what are the measure
should i go for it size is by length 30 feet x 23 feet width
Tue Oct 30, 2012Post  #1
Dear Rajesh
There are many steps for under taking the construction of swiming pool.
1. Excavate the pool in the ground according to the required size, care should be taken that the bottom layer of the foundation should be compacted.   There should be no soft places in foundation due to roots etc.  Any soft/ defective spots should be dug out and be filled with concrete/ hard material.
2.Lay bottom layer of cement concrete with care that the concrete should be mechnically  mixed and well compacted.
3. Construct the R C C side wall and lay floor concrete but care should be taken that the concrete should be mechnically mixed and vibrated, the sand used in the concrete shoud be washed coarse sand with silt not more than 4%, care should be taken that there should be no voids in the concrete.
4 finish the surface with glazed or ceramic tiles.
Main point to be kept in mind  while construction is that all the process done simultaneously and without giving long gaps means the work should not so dry before taking the next step, if this this may creat leakage.
For more information visit website gharexpert.com construction section where you can find lot about construction.
3572
2617
direction for swimming pool
Last answer on 9/9/2010 1:46:11 PM. by sabina vanjani. Forum started by rajkumar
2248
sir, what are the precautions need, to make a swimming pool on the roof.
Last answer on 10/6/2021 6:10:46 AM. by S L Gupta (Civil Engg). Forum started by Gagan Matharoo
2368
2438
Last answer on 5/10/2012 7:34:26 PM. Forum started by MAHESH DHOMANE
2071
Is it good to buy a plot with swimming pool in the south? Is it good to buy a p
Last answer on 12/31/2020 2:51:34 AM. by sabina vanjani. Forum started by kamlesh bhavnani
4607
swimming pool construction
Last answer on 9/5/2021 4:54:13 AM. by S L Gupta (Civil Engg). Forum started by veby
7407
Last answer on 7/20/2020 11:36:14 PM. by Gunjan Utraja. Forum started by srinivas
3485
Water leakage from the Swimming Pool
Last answer on 8/5/2020 12:58:17 AM. by S L Gupta (Civil Engg). Forum started by S. K. Agarwal
2419
Inground Swimming Pool
Last answer on 5/7/2010 9:31:08 PM. by naser. Forum started by ajit
2529
Complete Swimming Pool Construction Consulting & Execution
Last answer on 6/24/2021 12:35:33 AM. Forum started by Gunjan Utraja
2979
Query regarding Estimation and details required for swimming pool construction
Last answer on 12/28/2011 10:10:25 PM. by Edward. Forum started by Mukesh Singh
2040
pl see this nice question.....or a doubt..ican naarate how somebody in house wit
Last answer on 12/7/2021 2:15:00 AM. by sabina vanjani. Forum started by D.Ramachandran
2346
I am planning to build a north facing house. In the plan i have the swimming poo
Last answer on 4/4/2011 6:47:39 AM. by arun. Forum started by anantha
2146
Extension at South West and North West, North and North East Missing
Last answer on 10/16/2011 2:42:06 PM. Forum started by Raveen
3128
Importance of Water
1883
swimming pool is located behind my flat in the south west direction. is it good
Last answer on 11/8/2021 12:15:45 AM. Forum started by L.Ramakrishnan
1819
Can a swimming pool be constructed in the basement of the house? It means living
Last answer on 8/28/2010 10:58:26 AM. by S. K. Agarwal. Forum started by S. K. Agarwal
6271
Water Tank Quality
3114
Hot Water Tank
2915
Sand in Water
3380
Diverters for Bathroom
2561
2145
40516
2083
GI pipe Vs CPVC pipeline
2931
1755
2080
Toilets
1988
Wall mounted cummod vs normal
5055
2775
2388
1855
2541
water softner
2682
commode type and flush type
4193
to shut off water to house
Inground
Swimming
Swimming
Swimming Pool Maintenance
Maintenance of a pool is a major requirement that must not be taken lightly. Read this article to know tips on how to ..
Pool
Pool Heaters
You spend a lot of money to construct a swimming pool and on its other equipments. But if your pool is frequently too ..
Tips for Swimming Pool Lighting.
Water presents a challenging and rewarding medium for lighting. Swimming pools, fountains, waterfalls magically come t..
Swimming
Swimming Pool Filters
Swimming
Swimming Pool Covers
Pool covers become an important thing when the swimming season ends. As they reduce evaporation as well as protect you..
Pool covers
At the end of the swimming season there is a hard need to to cover the swimming pools with pools covers. A pool cover i
Pool cleaning.
Pools are a great way of cooling and comfort. Pool cleaning is necessary to to enjoy a comfortable bath. Cleaning protec
Pool Pumps
