Steel
Sun Jul 07, 2013
AMIT KUMAR VERMA
Topic: TMT Bars (Thermo Mechanically Treated Bars)
what is the price tmt bar now
The comment above talks about the article
"TMT Bars (Thermo Mechanically Treated Bars)"
Mon Jul 08, 2013
Dear verma
For price contact dealer of your city or near by, because they change rates time to time.
Thu Apr 16, 2015
BABU
Post subject: TMT Bars (Thermo Mechanically Treated Bars)
can we weld TMT bar instead of lapping in a column ....? as the length left for lapping in not enough....
Mon Jul 23, 2018
Thank you.
3753
Last answer on 1/30/2017 12:00:36 PM. by
1622
Last answer on 1/25/2022 12:11:46 AM. by
Muhammad
1588
Last answer on 7/4/2020 4:22:40 AM. by
Er.S.K.Jain
Vineeth V
1502
Last answer on 7/4/2020 2:17:25 AM. by
Betty Varghese
1529
Last answer on 9/16/2018 11:00:00 PM. by
Muhammad
2898
RCC Roof
Last answer on 7/4/2020 12:19:59 AM. by
ARVIND GOYAL
2627
Whether 6 x 8mm TMT bars are enough for rcc belt over rubble foundation for 2 story house?
Last answer on 9/30/2016 2:16:48 PM. Forum started by
3039
use of tmt bar
sonu.211
3059
steel formula
Last answer on 4/16/2014 8:05:15 PM. by
shaik khaja nayab rasool
13772
overlap length to steel
Last answer on 6/16/2015 4:11:51 AM. by
3179
Last answer on 3/14/2021 11:13:22 AM. by
venkatesan.pt.
2956
Need help for terrace room to cover iron bars (Picture Attached)
Last answer on 12/28/2012 11:27:53 AM. by
prabhjeet
4069
steel requirement
Last answer on 7/4/2020 2:20:25 AM. by
Raghavendra
3224
Size of TMT bar for RCC main slab and beam
Last answer on 1/27/2017 3:25:08 PM. by
Rahul
Rahul
24765
Last answer on 7/4/2020 12:22:02 AM. by
Techman
2156
TMT bars
Last answer on 12/24/2015 4:12:13 AM. by
Pooja
2129
what is the formula for calculating wt/ m for sq alluminium bars
Last answer on 12/4/2021 9:11:25 PM. Forum started by
1400
Last answer on 9/16/2018 10:58:39 PM. by
Vineeth V
1303
Last answer on 5/21/2018 3:33:47 AM. by
VivekC
RAJAT BANGA
2684
steel requirment
Last answer on 2/1/2022 2:47:12 AM. by
skziro
vijaygutti
15582
Last answer on 7/26/2021 2:26:58 AM. by
Residential complex
Last answer on 6/30/2021 4:27:52 AM. by
lali
4367
RCC Columns
Last answer on 4/14/2021 6:24:55 PM. by
Ahmed
Ahmed
3238
Last answer on 12/31/2020 2:29:45 AM. by
Prem Bhatia
Shabbir Manzoor
7479
Bar Bending Schedule Software
Last answer on 12/13/2020 8:18:39 PM. by
kongrollo
Prasenjit Roy
2521
steel
Last answer on 7/3/2020 10:06:06 PM. by
saravana prabu
29941
Last answer on 9/26/2018 12:16:44 AM. by
Balaguru
9362
Last answer on 5/21/2018 11:53:16 PM. by
George Kattapuram
2260
Current iron rod price
Last answer on 4/23/2018 11:26:02 PM. by
lio
2605
Last answer on 1/27/2017 1:11:45 PM. by
1885
Steel Erectors
Last answer on 8/22/2016 11:36:29 AM. by
MarianneRolfe
MarianneRolfe
Last answer on 4/18/2016 11:23:43 PM. Forum started by
Kaleemullah
Kaleemullah
2382
Last answer on 1/11/2016 2:34:47 PM. by
DURJOU KUMAR MONDAL
DURJOU KUMAR MONDAL
3266
Last answer on 1/11/2016 12:39:36 PM. by
DURJOU KUMAR MONDAL
13772
2160
Last answer on 12/26/2014 1:19:11 PM. by
pramod Kumar patel
2539
Last answer on 10/12/2014 9:10:09 PM. by
Rohit Patel
Dining Chairs and Bar Stools
What are the various accessories recommended for Aluminium doors?
Various accessories for Aluminium doors :Door Handles,Door Fasteners,Door Viewers....
